6k/3k installed
Old Nov 20, 2010 | 11:43 AM
  #91
5150DS's Avatar
Originally Posted by lowerd4lyfe
So you just bought the H4 bulb....not the H4 Hi/Lo correct?
The regular H4 (not HiLo) doesn't have the eyelash problem. Screensaver has no problem with his. Not sure of any other G with the Hi/Lo.
I will take a pic of the bulb and shield this weekend, to show.
Thanks for the posts.
Just wondering if you turned the bulbs over and that corrected the problem?
Old Nov 21, 2010 | 03:10 PM
  #92
thescreensavers's Avatar
Mr.202?
^ I am pretty sure he had to get the normal H4 bulbs. the Hi/lo bulbs do not work.
Old Nov 21, 2010 | 03:16 PM
  #93
toymachine2009's Avatar
damn cheap and effective I wanna order some.. So you have HIDS in your headlights and your fogs correct?
Old Nov 21, 2010 | 03:26 PM
  #94
Max626's Avatar
I still believe the high/low will work like i said b4 he installed his upside down. If i get a chance 2morrow ill swap one of my hid kids with my coworker who has the hi/how
Old Nov 21, 2010 | 03:29 PM
  #95
Mr.202?
Yep, I also just changed the bulbs for the low beams. So I got HID Lows and Fogs
go for it, let us know.
Old Nov 21, 2010 | 04:17 PM
  #96
okay because currently my Fog light and Turn signal are both out.. Do they work off the same bulb?
Anyways I wanna change everything to HID like you did.. There doesnt happen to be a DIY for this is there?
Also You ordered from this http://www.ddmtuning.com/product.php?II=101 so you ordered same kit just different bulb type and color?
Old Nov 21, 2010 | 04:20 PM
  #97
Mr.202?
Fog and signal are different. I wonder if they are on the same fuse should check that out.
Not sure might be, there is the fender lining you take off and its all there in reach.
Yep the Slim kit, 3k bulb for that you can choose another. And I picked up 6ks for the low beams.
Old Nov 21, 2010 | 05:27 PM
  #98
okay let me get this straight.. Sorry for the newb question
Your 6k is your headlight HID
Your 3k is your Yellow HID (Fog light)
Now each kit is $35 so you spent a total of $70 for 2 kits and in each kit came a PAIR of HIDS correct?
Also was a Relay needed? I saw an installer put a HID kit in a car yesterday and used a relay which made things more complicated... After he was done he goes Plug and Play My ***.. I dont want this to be complicated lol. Said he used the Relay because the bulbs werent getting enough power or something and they were just flickering..
Old Nov 21, 2010 | 06:11 PM
  #99
Max626's Avatar
For your headlamps you just need a replacement bulb, not the full kit. Everything needed for the install is included
Old Nov 21, 2010 | 08:14 PM
  #100
Mr.202?
Its plug and play for the G lol.
My Headlight is 6k, I just bought a bulb for that.
I then bought the Slim HID kit with the 3k bulbs for the fogs.
So I paid for 4 bulbs and a HID ballast for the fogs. Then plugged everything in. The Digital Slim Ballast actually fits inside the fog light housing. DDM said "it should not pose any issues" so I am rolling with it.
Old Nov 21, 2010 | 08:29 PM
  #101
so that link is just for the kit though right?
You Order your bulbs for $35.. and where it says HID Harness you select Dual in and Dual out for +$12.50 and thats your HID ballast?
Old Nov 21, 2010 | 08:31 PM
  #102
Mr.202?
^ I got none of that stuff, Just the bulb and the 35watt Ballast.
Old Nov 21, 2010 | 08:45 PM
  #103
okay i guess... so umm your fogs and headlights were H4? Or just your 3k fogs are?
Edit: Ohh Okay D2R is the type of headlight bulb you got and H4 is the fog lights you got! I get it!
When I selected D2R and 6K for that.. right there was just $50 then I gotta also add H4 3k for another $35?
Im confused
Old Nov 21, 2010 | 11:52 PM
  #104
Mr.202?
where are you getting 50 buck option from? Just click on HID bulb replacements they are like 12.50 now. And Yep D2R.
H4 is correct for the Fogs for the HID kit. which is 35 bucks.
Old Nov 22, 2010 | 12:26 AM
  #105
Ahh okay I see thanks man I get it now.
Ordered
