6k/3k installed
Old Nov 23, 2010 | 04:21 AM
  #106
5150DS's Avatar
Originally Posted by Max626
I still believe the high/low will work like i said b4 he installed his upside down. If i get a chance 2morrow ill swap one of my hid kids with my coworker who has the hi/how
If you don't mind, take pics with the bulbs in both ways to show if the "eyelashes" are there. TIA
Old Nov 24, 2010 | 12:58 PM
  #107
hi-tek22's Avatar
did the OP ever have a chance to flip the hi/low bulb around to see if the eye lashes disappeared? If so Ill get a set
Old Nov 24, 2010 | 06:05 PM
  #108
toymachine2009's Avatar
The op didn't have eye lashes nor did he use hi/low bulb
Old Nov 24, 2010 | 06:14 PM
  #109
lowerd4lyfe's Avatar
Sorry Guys I havent had much time to get on here...I have been super busy with work....
And to answer your question, I did not get a chance to look at the bulb and see if it turns upside down. I have the HI/LO H4 3000K bulb. It does work, the housing from what im told is not capable of handling such high discharge. The H4 HI/LO bulb is alittle longer than the regular H4 bulb. Hope I answered all your questions. I will try to get to my bulb this holiday weekend since im off work. Will post pics asap! Happy Holidays
Old Nov 24, 2010 | 08:48 PM
  #110
Max626's Avatar
I also forgot to do the swap while at work this week, if lowerd4lyfe isn't able to fix his this weekend i will make sure to do it when i return to work next week.
Old Nov 26, 2010 | 06:31 PM
  #111
Just installed mine! I am loving the yellow looks really good. Few questions though.. First when I hit my highbeams my fog lights go off... and second my hid headlights not the fogs are really high.. Feels like I got my high beams on because they are lighting up things my Highbeams would like the tops of houses and tall signs etc. VERY bright lights
Old Nov 27, 2010 | 01:47 AM
  #112
thescreensavers's Avatar
Mr.202?
^ When you hit your High beams it wants to switch the fog lights to high beams. Since these are not Bi-Xenon ballasts(might also include bulbs) you do not have high beams.
If you noticed, When you installed the Kit, it plugged into 2 out of the 3 plugs.
hmm, tops of houses? I do know there is some dim light that does shine up a bit, so it lights up reflective signs. Stand in front of your car you will see what I mean. Its not that bright as you can stare into it without any discomfort.
As well as people who I drove behind, when asked said there was Zero glare and everything was good.
Quick question, how long do the 3k's take to warm up?(go yellow)
Old Nov 27, 2010 | 01:52 AM
  #113
You noticed too that yellows took a sec to fully light up.. For me only a few seconds to light fully up at first I was like boo but when they were lit they look awesome.. I had my girl drop me off on side of the road and I watched it do a drive by and damn they looked super nice!!
Again my only concern is it feels like I'm driving with high beams I'm lighting up balconys on houses as I drive through my neighborhood.. And things I could only do before when my high beams are on..
Definetly loving the hids very good mod for the buck.. I suggest to anyone who doesn't have hids to pick some up
Old Nov 27, 2010 | 02:00 AM
  #114
Mr.202?
^ hmm, you sure you installed the bulbs correctly? Can you Take a picture on a wall with just the Lows on? You It should not be lighting up anything more then stock other then reflective highway signs(which is what I noticed)
My Fogs take like 30sec till they go yellow lol, do yours take that long?
I been reading apparently the DDM Ballasts can do hi/lo through the hi/lo bulbs. Hopefully they guys with the hi/lo bulbs can do some testing and possibly get those bulbs working without the eye lashes.
Old Nov 27, 2010 | 02:06 AM
  #115
I'll take pics and show you.. I'd say maybe 20 sec or less.
I'm fine with no highs these are super bright..
Old Nov 29, 2010 | 06:36 PM
  #116
^^ From what it sounds like, you are having the same problem i have, with the eyelashes. When the fogs are one, there is light shinning outward. therefore lighting up the neighbor ladie changing in the window, and the high street signs. When I talked to DDM about it, they stated the g35 headlamp housing is not made for the high intesity of the bulb, creating the light beams to bounce different places.????
Ive been having some family medical issues, so taken a pic of my lights right now, are on the bottom of the list. Hope MAX626 can get a pic to show. THanks
Old Nov 30, 2010 | 12:12 PM
  #117
5150DS's Avatar
Thanks for getting back, hope your family member recovers quickly.
Old Nov 30, 2010 | 01:38 PM
  #118
Mr.202?
hmm, I thought he was talking about the lows. the Fogs are like highs and lighting the place up?
my fogs do not do this at all
Old Nov 30, 2010 | 06:57 PM
  #119
Did you get the Hi/Lo bulb....or just the fog?
Old Nov 30, 2010 | 09:14 PM
  #120
just the fog No Hi/Low bulb here. I think my headlights just need to be aimed because they are kinda high. My fog lights are fine and no problems with them.
