The "Look what I made/installed/modified today" thread.
Old Sep 30, 2010 | 03:40 PM
  #151
mr_luv's Avatar
Pop them in the oven for 20 mins at 250 degrees .
Originally Posted by kyemaul
how did you get inside the light. i want to paint something inside my light red. im hearing you have to bake them bcause of the factory seal. is that true?
Old Sep 30, 2010 | 05:31 PM
  #152
kyemaul's Avatar
im going to do what the DIY says !!!
Old Oct 1, 2010 | 02:25 PM
  #153
ttrank's Avatar
Grocery getter
And now, back on topic.
Old Oct 1, 2010 | 06:17 PM
  #154
NFSP G35's Avatar
? = 2B || !2B
How about what I'm working on right now?
(btw, i don't know what the bluish color is all about, my phone fails at color it's actually just primer atm)
Old Oct 1, 2010 | 06:37 PM
  #155
kyemaul's Avatar
is that an intake manifold?
Old Oct 1, 2010 | 06:40 PM
  #156
NFSP G35's Avatar
? = 2B || !2B
^That's your intake manifold silly
Yeah, it's the lower plenum turned upside-down. That's why you don't recognize it.
Old Oct 1, 2010 | 06:48 PM
  #157
NFSP G35's Avatar
? = 2B || !2B
Couple more coats, and we're good!
Old Oct 1, 2010 | 07:26 PM
  #158
naughty240's Avatar
Ashley did you consider smoothing out that texture on the parts you can see?
Old Oct 1, 2010 | 08:20 PM
  #159
NFSP G35's Avatar
? = 2B || !2B
Originally Posted by StormTroopa
should have got a mrev2 and PCd it
No interest in spending that much money right now. I can afford $20 in paint... I'll save the larger amounts for other mods (for now)
I considered it.... and that's about as far as it went
I really don't mind the texture, just needs to be black.
i didnt realize it was upside down never had to take mines off or apart. Soon tho when i get my spacer!!!!!!!!!!!
Actually, you won't have to take the lower half off for the spacer
Old Oct 1, 2010 | 08:24 PM
  #160
CG4DR's Avatar
hopefully it matches the other black
Old Oct 1, 2010 | 09:24 PM
  #161
NFSP G35's Avatar
? = 2B || !2B
^What other black? I'm painting the upper and lower plenum.
Old Oct 1, 2010 | 09:45 PM
  #162
NFSP G35's Avatar
? = 2B || !2B
Don't do polished, do chrome. Looks better, a good job won't flake, and it's super easy to keep clean (polished aluminum is a PAIN to keep perfect because it constantly oxidizes)
(Sorry Corey )
Old Oct 1, 2010 | 09:50 PM
  #163
CG4DR's Avatar
heat will distort the color of chrome.
like Ashley said if you get it done real good than you shouldn't have a issue but finding a good place to do a good job is the real problem
Old Oct 1, 2010 | 09:54 PM
  #164
CandlestickPark's Avatar
ill Sedan
Hit up SxExCx for polished goodies in your engine bay.
Old Oct 1, 2010 | 10:02 PM
  #165
CG4DR's Avatar
who does emblemless grilles?
