The "Look what I made/installed/modified today" thread.
Just noticed that after you mentioned it. It's a lil off center. Pain the **** to get them centered. I wanted to go a mm larger but it wouldnt clear the dial or the casing. Oh well. Too lazy to take it apart and redo.
I didn't pay much attention. I just recall seeing the back of the circuit board. It's quite easy to take it out though.
1. Pull the top frame on the dash board out.
2. Use a flathead screwdriver to pry off the low part out in front clock.
3. Unscrew two screws in front of the clock.
4. Tilt the top part of the clock towards you and pull out.
5. Unplug harness in front of clock on the bottom right.
Rest you can figure out quite easily. Just screws.
cool. thanks
yeah tried to take it apart but you have to take the hands off the clock to get it fully apart and i don't want to mess it up
