Projector Headlight project
Old 01-18-2011, 09:52 PM
r1forever80's Avatar
Originally Posted by liljohnny
I'm sure you meant not too much trimming of the oem BEZEL and you're right. But when you add a shroud to the front of the projector, (I'm going with Apollo), I would think you'd have to trim a little more off the oem bezel so you have clearance for adjustment purposes. Can you share any pictures of your past retroes where you put the projector up top?
The apollo is a pretty big shroud. I wouldnt suggest putting it up top. That will require a whole lot of trimming of the projector shroud and oem shroud.
Originally Posted by Rodrigo
Ive been snowboarding in PA the last few days while my cars still qt the dealer when I get it bad I will resume my project I was looking at the wiring and I thinking it's very possible to achieve what I want to do .
R1 how did u remove all of the original oem shroud to expose te box located behind the bottom shroud. ?
I too agree the shrouds are to flimsy to drill into that's how I have them now , I'd like to make a bracket to have them better attached . I think just attaching to the shroud going over rough roads will crack or damage the shroud
The oem reflector has 2 adjustment screws and one pivot point. Tne shroud just pulls off the pivot point. you will need to just unscrew the adjustment screws all the way out
  #47
Old 01-19-2011, 02:36 PM
liljohnny's Avatar
R1, you may be right about the Apollo, I've been dry testing though and it seems the best equipped to cover the entire projector and old reflector area. It will require some serious trimming but I fail to see how any shroud will not require this and still cover the entire projector body....pics?
  #48
Old 01-22-2011, 07:09 PM
Rodrigo's Avatar
\\update,
ive been working on them the last 2 days , i did all the wiring to make it look oem as possible, i wired it so my projector on the bottom is the lo / hi beam
and my oem top xenon works as my fog light.
i aimed them using a 25 feet of distance and adjusted the projector to balance the cut off.
success !!! they work great took some adjusting to get them to be the same i think im 98% -on point with the equal cut off.
i just need to get back now and install the bumper.
  #49
Old 01-23-2011, 11:44 PM
Rodrigo's Avatar
FINISHED!
they look and work fantastic , the color is just right and the way it looks is just sick.
im very happy with the results , pics will be up soon .
  #50
Old 01-28-2011, 02:20 AM
Rodrigo's Avatar
  #51
Old 01-31-2011, 12:06 AM
Rodrigo's Avatar
1 week update , lights have been running great , they are so bright but aimed a bit lower since its in the lower location .
Ihe bixenon feature is nice to have , over all a great mod but ALOT of work .
  #52
Old 01-31-2011, 12:14 AM
liljohnny's Avatar
Wall shots at 25' of your low beams and your high beams!
05-22-2022 09:26 AM
Marlin84
04-01-2020 12:52 PM
Picture Share
02-04-2018 12:41 PM
Batfinity
Lights
09-27-2015 12:29 AM
Quick Reply: Projector Headlight project
