How to remove plastic dip?
Mar 15, 2012 | 08:53 PM
hey guys i have a problem. i plastic dip my stock wheels and painted them gold. and now im trying to remove it and im having a really hard time. i tried using a power wash and its not work any ideas on what i could do? plz help
Reply 0
Mar 15, 2012 | 08:58 PM
All you need to do is get something pointy - be careful of the rims- and bring up an edge. From there, peel it all off. You can look at YouTube vids to get an idea - shouldn't take that much effort once you have a piece up.
Reply 0
Mar 15, 2012 | 09:06 PM
I did this to my evo wheels back then just to see what black wheels looked like.
The plastidip peeled itself after a couple days.
Reply 0
Mar 15, 2012 | 09:08 PM
Most ppl don't apply it thick enough to just peel it all off so an awesome way to get it off or break it down I shld say is to use GASOLINE. It sounds crazy but it works really well. Just make sure you are in a well ventilated area. Good luck.
Reply 0
Mar 16, 2012 | 09:59 AM
Brake cleaner should also make it peel.
Reply 0
Mar 17, 2012 | 04:19 AM
thanks everyone. but my wheels are not just plastic dip they are painted over with a gold spray paint which made the plastic dip very weak and now is SUPER hard to come off. i wish i just did plastic dip that way it would of been so much easier to just peel it off.
Reply 0
Mar 17, 2012 | 05:22 AM
heat it up.
Reply 0
Mar 17, 2012 | 08:36 AM
A good way to remove it it's by calling it the correct name. Plasti dip not plastic dip
Reply 0
Mar 25, 2012 | 12:45 PM
Even with the paint, it should be relatively easy to peel off if you can get a edge started.
Reply 0
