need pics 19x10.5 with +12 offset on 03-06 sedans
Old Oct 15, 2012 | 10:06 AM
INFINATEnIsMo35's Avatar
Whats up people i have a 04 sedan lookin for pics of anyone who has wheels thst are 19x10.5 with +12 offset i am looking to buy a set but unsure how they would fit on sedan they currently have 245/35 onthem.. any input would greatly help thanx again
Old Oct 15, 2012 | 11:03 AM
Dan@Assaultech's Avatar
Trying to run them all the way around or just in the back? I can tell you we are running a 10.5 +22 245/35 in the rear. Car is running 4.1º of camber to make them fit. You will need even more camber and possibly a smaller tire.
Here is the car
19x9.5 +12 (after 10mm Spacer) 225/35 2.7º & 19x10.5 +22 245/35 4.1º
Old Oct 15, 2012 | 11:15 AM
It would be all around but i was gonna run 245/35 rears and 225/35 fronts no spacers and actually are those samw wheels as the pic. So them rear ones are +22 or +12
Old Oct 15, 2012 | 11:16 AM
+22 in the rear. The fitment you are talking about would stick out another half inch front and rear
Old Oct 15, 2012 | 11:38 AM
Damm i really wanna get them wheels just that offset is killing me dont want the car to look crazy wit them stickin out so much i currently have the Es1.1.2 19x9.5 fronts with +22 and 19x11 +22 and i have to camber quite a bit on rear idk
Old Oct 15, 2012 | 05:04 PM
Adro's Avatar
YAH dog I knoz wat uz sayin
Old Oct 15, 2012 | 05:15 PM
CandlestickPark's Avatar
ill Sedan
+12 out back, -6 camber and a 235/35 tire. Fenders were cut (would have been better to pull them). Fronts are 9.5 -3.
https://g35driver.com/forums/media-s...ld-thread.html
Old Oct 31, 2012 | 02:07 PM
Looks gd i got same color... Problem is that my i cant do tires every month lol..
Old Oct 31, 2012 | 05:22 PM
ArkansasG35COUPE's Avatar
Wish I had that Assaultech Sedan sooo bad! Thats my wallpaper!
Old Oct 31, 2012 | 05:29 PM
JaE35's Avatar
Moderator
G35 Sedan
9.5 +12 up front and 10.5 +22 in rear looks awesome
Old Nov 1, 2012 | 04:20 PM
P10 WRC's Avatar
depending on how low you are, you will need to roll the rear fenders flat and a slight pull to make them fit. also as mentioned above at least 6 degrees of negative camber which would require aftermarket camber arms and toe bolts to get the toe back in spec. stock camber arms can give you about -4.5 degrees of camber max. you could make that work with more of a pull on the rear fenders.
Old Nov 2, 2012 | 04:58 AM
4drSS_V35's Avatar
hey bro i bought those same exact wheels and i was wondering on what ur feed back on the 19x11. any pix of that on ?
Old Nov 2, 2012 | 05:10 AM
Well i stopped running the low offset on my car its my daily and i went through a set of tires in rear in month befor i had wires showing i went back to stock rays for the winter and ill decide by begining of yr wat ima run.. thanx guys for the pics and input
Old Nov 2, 2012 | 05:13 AM
4drSs v35.. i ran 19x11 +22 offset and those wer the ones i killed tires in a month.. just givin u heads up i had a previous set 19x10.5 with +30 offset and and tires lasted alot longer and had to use less camber
Old Nov 19, 2012 | 04:58 AM
4drSS_V35's Avatar
im running the 19x11 +25 setup right now at 3.7 degrees and the tires are barely touching fender just rolled and no pull. kinda amzed it fits and im a bit lower then the g Marcus posted
sorry crappy pic
