G57 Sedan Build Thread
Old Aug 26, 2017 | 08:34 AM
  #31
G35Drew's Avatar
G57
No big plans this weekend. Going to try and get the driver's side header on. My FPR/filter came in yesterday from Speedway Motors. I'm gonna try and find a good spot to mount it and measure out how much fuel line and which AN fittings I need to order. If time permits, I'll try and get the rear subframe dropped and start working on those bushings.
Old Aug 26, 2017 | 02:43 PM
  #32
Urbanengineer's Avatar
Poly bushings should be same noise as stock with the energy bushings grease. Not squeaky or harsh. I love mine!
Build looking shiny clean and fast. Lots of fun with NA HP.
Old Sep 2, 2017 | 03:32 PM
  #33
G35Drew's Avatar
G57
Exhaust is gonna be loud on first startup
Plenty of clearance for access to everything
Heat sink coil packs and NGK wires on
Stopping for a few hours. Gotta watch the Gator game.
Old Sep 2, 2017 | 11:02 PM
  #34
G35Drew's Avatar
G57
Got the power steering and oil filter lines installed
Painting the FAST 102 black again. The previous owner had it bright white.
Still much more to do
Old Sep 3, 2017 | 07:29 AM
  #35
Blue Dream's Avatar
I drove ttrank's car solo
Car's looking good!!
Old Sep 3, 2017 | 08:13 PM
  #36
G35Drew's Avatar
G57
Energy Suspension rear set
Not too bad to install, the grease everywhere is the worst part
Got the Wilwood clutch master on
Got bored with the green paint
Wiring Specialties harness fits just like OEM
I think there's room next to the blower motor to tuck the computer behind the glove box
Waiting on the new lower intake and throttle body gaskets to show up
I got the rear subframe ready to drop. My impact ran out of batteries so I'll tackle that tomorrow. Alternator and PS pump with all associated brackets are on order. Still need to order rear wheel hubs and bearings and finish pressing in the rear poly bushings.
Old Sep 4, 2017 | 05:10 PM
  #37
G35Drew's Avatar
G57
Old ball joints out and new ones in
Driver's side front almost complete
I started removing the 4 subframe bolts but they are being stubborn. I let them soak all night in Blaster. I got 3 of them about halfway off so I gave them another coat of Blaster and will let them soak overnight again. Lots of parts on order. Busy week with work and school so all car work is put on hold until the weekend. If the fuel lines show up this week, I may be able to start her up this coming weekend.
Old Sep 5, 2017 | 12:12 PM
  #38
MikeG35Coupe's Avatar
20 Year Member
One owner 2004 G35 Coupe 6MT
Very impressive. Can't wait to see (and hear) this when it's finished.
Old Sep 5, 2017 | 12:31 PM
  #39
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Yeah, definitely want a video of the finished product.
Old Sep 7, 2017 | 04:42 PM
  #40
G35Drew's Avatar
G57
Got the new intake manifold and throttle body gaskets put on. Rear upper control arms showed up today so I can get the new poly bushings pressed into them. Dirty Dingo alternator and power steering pump brackets also showed up along with the TurnOne power steering pulley. The alternator and power steering pump should be showing up tomorrow so hopefully this weekend I can have everything ready for a test start minus the fuel line and a few AN fuel fittings.
Old Sep 9, 2017 | 06:17 PM
  #41
G35Drew's Avatar
G57
Wiring Specialties harness all connected on the top side
Old Sep 10, 2017 | 07:34 PM
  #42
G35Drew's Avatar
G57
Routing and measuring the 6an hose
Pressure line and return line
Mounted the FPR to the transmission mount
The fuel lines will hide nicely above the driveshaft and away from the exhaust
Test fit the intake and radiator support
Still need to source a radiator. I've been in touch with Mishimoto to try and get something custom made. I was 1 fuel fitting short of getting the fuel lines finished, gonna order that tonight. Belt tensioner is on order. Still need to finish dropping the rear subframe, if the bolts decide to cooperate. I siphoned as much old fuel as I could out of the tank. Who knows how long this car sat before I bought it? A new blue fuel o-ring was installed.
Old Sep 10, 2017 | 07:39 PM
  #43
cleric670's Avatar
BANNED!!!
Looks fantastic, didn't siphon when the pump was out?
Old Sep 10, 2017 | 07:43 PM
  #44
G35Drew's Avatar
G57
Yeah I did. I couldn't get everything out. I figure a full tank of 93 on top of whatever is left in the tank should work just fine.
Old Sep 10, 2017 | 08:00 PM
  #45
cleric670's Avatar
BANNED!!!
Ahhh, never looked inside the tank on these things, probably all manner of baffles yeah?
