Heat Wrap installed
Heat Wrap installed
So I finally got all my bits and pieces to install the heat wrap on the Invidia Q300. I wrapped all the pipes apart from the Y-pipe because I'm waiting to upgrade it to the new re-designed ones (and I don't want to run out of heat wrap) anyway enjoy the pics and bare in mind this is the first time I ever wrap anything so go easy on me :
Below shows the difference between how the wrap looks before spraying and after spraying:
Just waiting for the X-pipe to dry and I'll be spraying it tomorrow:
BTW I'll be cutting the excess clip ends before installation
Thanks, the x-pipe was a bit odd due to the welded section in the middle, but I started off from the back on one of the pipes and wrapped up to the weld, then I just overlaid one roll to the other side just to cover it from the top, I sat there thinking about it for a bit and figured not a lot of heat will be coming out of there so it should do, it's just the welds and a bit of the pipe not covered from the inside....does that make sense?
lol this is the second time I answer this question today:
Well it's supposed to do a bunch of things:
- Keeps exhaust heat in, makes gases flow better out the rear end
- Should help reduce drone noise from the exhaust
- for me personally it's to reduce any heat coming from the exhaust when I open my door and just sit there, Hopefully it'll help me out there. I just wish I did it to my HFC's but they're already on and I'm not arsed to take them out
