View Poll Results: Which problem should we fix first
Fan
0%
CAMSHAFT
0%
Passenger side windows
0%
Or the senors
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
We need advice any advice on what to do with this damn car anybody having suggestions
Ha everyone this is Tanya and bonnie we have a 2003 g35 AT COUP INFINITY WE JUST INHERITED WITH QUITE A BIT OF PROBLEMS NOW ONE THE FAN ON THE DRIVER SIDE STOPPED WORKING MAYBE THE RADIATOR FAN STOPPED WORKING PASSENGER SIDE WINDOW DIDN'T ROLL UP AND OVERHEATS WE GOT TO SLIP AND A COUPLE OTHER THINGS ON THE DASHBOARD LIGHT UP. CHECK ENGINE LIGHTS ON AND WE DID DIAGNOSTIC CODEINE READING AND IT SAID WE NEED TO FIX PRIMARY DTC REPLACE CAMSHAFT POSITION SENSOR (CMP) A" CIRCUIT"..
P0340 CODE P0340 INDICATES A IN THE BANK 1 OR SINGLE SENSOR CAMSHAFT POSITION SENSOR A ELECTRICAL CIRCUIT FOR A FREE DETERMINED. OF TIME
P0462 FUEL LEVEL SENSOR A
Tanya! Bonnie! Please don't shout at us!! Now...
1. Replace the camshaft position sensors (both of them). Use only OEM or Hitachi (OEM manufacturer) sensors.
2. Need more info on the dash lights. Which ones, and provide the entire list of diagnostic codes for folks here to use to help you.
3. Radiator fan MAY be the motor/clutch assembly if one is working and the other not. It's a two stage system. If it's not hot outside and you are not racing around and the AC isn't on, it may only be running on one fan because the demand isn't there to require two fans to keep temps in line.
4. The P0462 fuel level sensor alert may or may not be the sensor. Could be a number of things. There are lots of threads on the forum for this code. Hunt them down and read all about it.
5. Since you don't pay tolls or get drive-through McDonalds through the passenger window, that's your lowest priority. It's probably the window motor needs replaced, but sometimes it's the switch in the passenger door, but it could also be the master switch in the driver door. YouTube has videos for switch and motor replacement.
Also, this sub forum isn't the place to post questions. It's the place to post your intro to the community. Tell us a little about yourselves. With good fortune, a moderator will move this thread to a more appropriate sub forum where perhaps more folks will see it.
Santi612
Jul 5, 2021 12:18 PM
Paul7296
Aug 20, 2020 11:29 AM
