NorthWest Serving AK, ID, OR, WA
my wheel bearing is on the way out 06 coupe wtf?
Old Feb 28, 2007 | 05:09 PM
djdannyj45's Avatar
I have 25000 mile on the car drive it pretty sane and the only thing i can think of is my heavy *** wheels ahhhhghg. Anyways anyone ever replace this? It is my front left that is bad. I just lowered on sunday and should have probably done it then just have never done it before... any idears?
Old Feb 28, 2007 | 05:10 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
i had an 06 coupe with 11000 miles come into my shop with a busted RF wheel bearing. Take it to the dealer, they should replace it under warranty.
-GP-
Old Feb 28, 2007 | 10:30 PM
Drewer's Avatar
I have. I can do it for you in about an hour or so. I replaced my driver's side @ 100k because it went bad. I just replaced my passenger's side today to make 'em somewhat even. BTW, order them from Beaverton infiniti in OR. They're like $60 cheaper and you'll get 'em overnight.
-andrew
edit: Warranty it first! Heavy wheels shouldn't wreck your wheel bearings THAT fast!
Old Mar 1, 2007 | 01:58 AM
aznj's Avatar
Broke Beyond Belief
how can you tell if your wheel bearing is bad?
Old Mar 1, 2007 | 02:09 PM
Drewer's Avatar
You'll hear an awful noise when going around corners, like a low pitched oscillating hum. Then when you jack the car up, one of the following will happen:
1.) Turn the wheel/hub and you'll feel a grinding instead of a smooth turn.
2.) Turn the wheel/hub and you'll hear a grind sound
3.) Push/pull the wheel/hub and you'll feel a slight motion in or out. (Worst case).
Hope you don't have to deal with it! But if you do, it's a rather easy fix. (No worse than changing your own brakes.)
-andrew
Old Mar 1, 2007 | 08:00 PM
djdannyj45's Avatar
do you want to do it sometime in the next month its annoying and how much would you charge a fellow g35driver member also how much is the wheel bearing?
Old Mar 2, 2007 | 01:49 PM
Drewer's Avatar
Wheel bearings at Fife are like $240. . .wheel bearings at Kirkland Inifniti were like $235 or something rediculous. If you order out of state (I got mine from Beaverton Infiniti, OR) and it was $180+$9 or so. There's a place in Minnesota that sells 'em for $160, but the shipping might offset that cost. Plus the parts from OR get her next day since they are close. Oh, those costs are all per bearing set. If you wanted to do both wheels, just double it.
I'd be more than happy to do it, you'd just have to drive up to Everett. Cost? Most likely nothing, or maybe a beer. It all depends on how much of a PITA the brake caliper knuckles are to get off. Do you have brembos?
-Andrew
Old Mar 2, 2007 | 01:51 PM
hit up Jason@RiversideInfiniti, he's got some of the best prices for oem parts.
-GP-
Old Mar 2, 2007 | 03:21 PM
Drewer's Avatar
I bought my car from riverside infiniti. The only downside to buying from SoCal is waiting two days instead of one, and the shipping typically is more. But definitely check out my car's birthplace. . .I stand behind 'em all the way!
-andrew
Old Mar 2, 2007 | 08:33 PM
djdannyj45's Avatar
i called the dealership and they said it was still covered i am going to give them a shot it just seems like i get dicked in the end.... If i do i will go your route drewer!!! thank you guys!!!!!!!!!!!!!!!!!
rezendvous420
May 31, 2020 01:26 PM
Xfactor
Dec 1, 2019 12:52 PM
teamghost
Jul 28, 2015 04:52 PM
rping
Jul 26, 2015 09:53 PM
itschuckster
Jul 25, 2015 08:07 AM
