Jack Stands and the G
Old Jul 6, 2010 | 07:42 PM
  #151
flipper325's Avatar
Originally Posted by nyckid
flipper i am curious, but do you have these made for floor jacks as well? I'd like to get one.
Not yet, but I'm thinking of making one. Basically, a tall hockey puck with a slot, or two orthogonal slots. I modified a jack pad I found online for my own use, but by the time I was done, it would've been easier to make my own from scratch.
Will your jack stand adpaters work for ppl with aftermarket sideskirts such as ings? I know the ings is very tall on the inside and i'm just worried about the adapters touching the sideskirts. Concerned about them clearing my sideskirts.
All G35 and G37 cars I've seen have 'pockets' in the sideskirts, precisely so you could support the car without damaging them. In fact, I sized the width of my stand adapters so they'd fit these pockets.
Old Jul 6, 2010 | 11:15 PM
  #152
nyckid's Avatar
Flipper I don't think my ings sideskirts have these pockets that you speak of. I was asking about aftermarket sides and not the factory ones.
Old Jul 6, 2010 | 11:56 PM
  #153
flipper325's Avatar
The short answer is "I don't know, it depends." If the pad fits under the lip so that there is only body-on-pad contact, then it will work. If the weight will be on the sideskirt, then it wont -- not without damage to the sideskirt. You'll just have to go outside and look at your car.
Old Sep 13, 2010 | 01:17 PM
  #154
labelworkshop75's Avatar
Just got a really nice new floor jack. I think I'm going to buy some hockey pucks and just drill out a slot so it will slip on the pinch weld and rest on the floor jack. Anyone make these jack adapters yet. I'll take a set of stand adapters
Old Sep 13, 2010 | 01:20 PM
  #155
WhosRich's Avatar
Yea, the guy who posted above you makes them. PM him for a price.
Old Sep 13, 2010 | 01:31 PM
  #156
Will the JACK STAND adapters fit these aluminum stands from Harbor Freight. These stands seem to be very flat, and not as deep as the others listed in the thread. ALSO, are there FLOOR JACK adapters available. http://www.harborfreight.com/automot...nds-91760.html
Old Sep 13, 2010 | 06:03 PM
  #157
flipper325's Avatar
PM sent. -Alex
Old Sep 13, 2010 | 06:37 PM
  #158
ilv2xlr8's Avatar
Originally Posted by flipper325
PM sent. -Alex
I have those same jack stands. I have a sedan though but I don't think that should matter. I'd be interested as well.
Old Sep 13, 2010 | 06:53 PM
  #159
flipper325's Avatar
A coupe or a sedan won't matter, but I'm not sure about the saddle curvature of aluminum stands vs. steel. These adapters can be made a bit flatter by using a file or a Dremel tool, but if you remove too much material under the slot, it could compromise the strength.
Here I was trying to keep the cost down, and we have all these wealthy guys buying aluminum stands...
Old Sep 13, 2010 | 06:56 PM
  #160
ilv2xlr8's Avatar
The jack stands are only $30 I wasn't sure either since sometimes harbor freight stuff can be a bit cheap but they seem sturdy. I'll find out this week when I actually use them.
If you want, I can take a bunch of pictures of the stands so you can get a better idea.
Old Sep 13, 2010 | 07:10 PM
  #161
flipper325's Avatar
Thanks, but what I really need are the measurements. It would be easier to just stop by the local HF, and compare steel and aluminum stand saddles side by side. I'll do that tomorrow.
Old Sep 17, 2010 | 07:44 PM
  #162
flipper325's Avatar
I finally managed to stop by the HF store today, to check out their aluminum jack stands. They have very shallow saddles, much flatter than the 3-ton and 6-ton steel stands. Unfortunately, my adapters won't work with them, or at least won't work well.
As has been mentioned in this thread, in addition to HF, there are several other stands that do work, with similar saddles.
Alex
Old Sep 17, 2010 | 11:26 PM
  #163
sjdaud's Avatar
A month or two I bought a set of these jack stand pads for my '08 G35. They work great! Thanks!
Old Sep 19, 2010 | 08:36 PM
  #164
ilv2xlr8's Avatar
Alex
These are the ones I have that you probably saw:
http://www.harborfreight.com/3-ton-a...nds-91760.html
Anyway you could fab something for that? I'd be very interested.
I've had the car up before but it just doesn't look perfectly snug since there is no adapter.
Old Sep 19, 2010 | 08:47 PM
  #165
flipper325's Avatar
Yes, that's them.
Given enough time, effort and money, everything can be fabricated. But it would be much cheaper for you to buy a set of steel stands for $15 -- HF routinely has them on sale.
I don't blame you for not being comfortable supporting the car without a proper fit. That was the reason I made these for myself and a couple of friends in the first place, and figured others could use them as well.
