Engine Bay Pics*Post here*
Old Jan 30, 2010 | 09:36 PM
  #1816
OCG35's Avatar
Originally Posted by SxExCx
^lookin' good Marcell!
Your source for any and all bolts is King Bolt in Covina.
King Bolt Co
4680 N Grand Ave
Covina, CA 91724
(626) 339-8400
I have every polished part in stock and I will have the matching overflow tanks in about a week.
Let me know if you need input with the wire tuck...I believe you have my number.
+1 for King Bolt! They have everything!!! My 1/2 cover wouldn't fit right with the stock grommets because of the 1/2" spacer - I went to King Bolt and got grommets, bolts, washers and spacers in precise sizes to make the height right... I could have never done that at Home Depot.
Old Jan 30, 2010 | 10:37 PM
  #1817
marcellsr's Avatar
Thanks Sean, and for the info on bolts. Yep i have your number and will be interested in the overflow.
Old Jan 31, 2010 | 05:44 PM
  #1818
Beebo's Avatar
Originally Posted by GreenGoblin
Beebs how much are they charging you out of curiosity?
not sure, i need to call them tomorrow and ask
Old Feb 18, 2010 | 12:29 AM
  #1819
cc_brandon's Avatar
Finished tucking the driver and passenger headlight harnesses last week, here's some pics. Hopefully going to have the rest of the parts polished soon
Old Feb 18, 2010 | 01:28 AM
  #1820
SxExCx's Avatar
Holy crap...I hope a good wash is in your car's near future
Old Feb 18, 2010 | 01:44 AM
  #1821
cc_brandon's Avatar
Nope lol. Car's staying in the garage until April when I have it painted Figured it was a perfect opportunity to do some of the longer jobs. I'm going to tuck the rest of the wires soon. Where did you guys run the passenger harness that runs next to the engine?
Old Feb 18, 2010 | 10:16 AM
  #1822
SxExCx's Avatar
^there is a hole just above the frame rail, next to the coolant pipe. All you need to do is drill a hole under the fuse box (in the batter compartment to feed it through.
Old Feb 18, 2010 | 10:29 AM
  #1823
GreenGoblin's Avatar
The goblin resurrection
Wow that is one dirty bay! What is that green wire, remote start? I see you are smoothing out the battery covers, nice.
Old Feb 18, 2010 | 11:28 AM
  #1824
cc_brandon's Avatar
The green wire is to turn on the DRL. I imported my car from the US and to register it in Canada, you need to have DRL. What did you guys do about the hole in the brake and battery compartments where the wires originally came through? I was thinking about welding a piece of aluminum there unless there's an easier way.
Old Feb 18, 2010 | 11:34 AM
  #1825
ShanesG's Avatar
Damn been a while since i been in here haha my bay is filthy atm
Old Feb 18, 2010 | 11:41 AM
  #1826
Heist.'s Avatar
yeah i think welding a piece of aluminum is the best bet i plan on doing that soon too . I would love an easy solution though other then welding.
Old Feb 18, 2010 | 02:25 PM
  #1827
PhantomIPG's Avatar
Welding the holes up with aluminum pieces??
Old Feb 18, 2010 | 02:33 PM
  #1828
Heist.'s Avatar
when you do a wire tuck you are left with a bunch of assorted holes. here is an example:
to clean it up we are talking about cutting a piece of aluminum out and welding it in the place of the hole. Does that help?
Old Feb 18, 2010 | 02:49 PM
  #1829
PhantomIPG's Avatar
...but the bulkheads are made of steel (sheetmetal)!
Old Feb 18, 2010 | 02:53 PM
  #1830
SxExCx's Avatar
I just painted a piece of plastic and taped it to the inside of the compartment.
