anyone slammed to the max on Stance coilovers?
Old Nov 6, 2009 | 11:00 AM
  #76
erklep's Avatar
Originally Posted by mr.stealth
yep, it's in the front this time it's a littie lower since last time you saw it got the coilovers installed and adjusted.
that stance is jst right! do you rub all the time up front or just when turning?
Old Nov 6, 2009 | 11:48 AM
  #77
(Stealth Inc.)'s Avatar
^ turning, bumps and dips.
Old Nov 6, 2009 | 11:55 AM
  #78
erklep's Avatar
what are your specs?
Old Nov 6, 2009 | 12:22 PM
  #79
BloodlineG's Avatar
dammn all these cars look good
Old Nov 6, 2009 | 12:34 PM
  #80
GreenGoblin's Avatar
The goblin resurrection
Originally Posted by donpisto
20k for the rear, meaning it would be somewhere in the 30k range?
I am pretty sure that is what he told me that they make the rear spring all the way up to 20k, but you would def need a revalve.
Old Nov 6, 2009 | 07:08 PM
  #81
OCG35's Avatar
Originally Posted by Kris79
you guys are nuts.... on my gr+ pros i jsut took out the helper spring lol.
how is the ride quality without the helper springs?... I have Tanabe on order (dare to be different ) and they have "helper" springs... They make a version without helper springs (all other specs are the same) -s o I know it can be done - but wondering about ride quality...
Old Nov 8, 2009 | 01:39 AM
  #82
gt30's 19x9.5+17 19x10.5+18 245/35/19 275/35/19 as far as camber, toe and caster i really don't know
Old Nov 8, 2009 | 09:06 AM
  #83
Springs came in... I will install them today and let you guys know the results.
Old Nov 11, 2009 | 07:44 PM
  #84
playatl's Avatar
That looks ridiculously amazing!!!!
Old Nov 26, 2009 | 10:05 AM
  #85
1YoungOwner's Avatar
Yeah I definitely need ThESE!
Old Mar 8, 2010 | 02:32 AM
  #86
yos3z's Avatar
I want to lay frame on my Z. Which Stance should I get or what other coilovers should I get? I don't want to spend no more than 2 grand and also what would be the best place to purchase it from. Sorry for reviving an old thread. Thanks in an advance!!!
Old Mar 8, 2010 | 03:20 AM
  #87
Royal_T's Avatar
Just to let everyone know I'm about to test some prototype coilovers that will be dedicated to slammed Zs/Gs. With the right spring right and Vavling and shorter housing.. Just be on the look out for my writeup...
Old Mar 8, 2010 | 10:43 AM
  #88
The Stimulation's Avatar
Will the be a true coilover setup or OEM setup?
Old Mar 8, 2010 | 11:07 AM
  #89
I had stance make my coils with shorter springs to ride slammed on true coils.
Old Mar 8, 2010 | 12:27 PM
  #90
Royal_T's Avatar
Yea they will be a true coilover setup. The problem with must companies is that when they offer shorter springs or higher spring rates they don't mess with the valveing to work with the springs, there for resulting in a harsh ride.
I will provide a full write up once I receive them and use them at the track and Daily Driving..
