anyone slammed to the max on Stance coilovers?
Old Aug 9, 2012 | 10:42 PM
  #121
SUMATIC's Avatar
Originally Posted by Johnnyone
Coils maxed out in the rear
Equals this
Would have thought i could go lower?
thats weird.
in the first picture it shows the rear maxxed out and its touching the locking ring to the bottom lock ring. on my stance gr+ it doesnt touch. when i max out the rears theres about an inch gap between the top lock ring and the bottom lock ring can someone answer me why?
Old Aug 13, 2012 | 10:55 AM
  #122
IvoryGT's Avatar
There is a higher preload on yours, hence the gap.
Old Aug 13, 2012 | 08:24 PM
  #123
SUMATIC's Avatar
But i set the preload to what stance recommended to me. Hand tight and one full turn. Thats what i was told over the phone. Though i set the preload with the strut not mounted on the car.
Old Sep 25, 2012 | 10:13 PM
  #124
Thatone_Gkid's Avatar
THmotoraports has these in stock only for 350z. The GR + for 350z will fit my 2006 G35 coupe right?
Thanks guys.
Old Sep 25, 2012 | 10:23 PM
  #125
SUMATIC's Avatar
check what year 350z its for.
Old Sep 25, 2012 | 10:26 PM
  #126
Says that they fit 2003-2009 350z.
Old Sep 26, 2012 | 03:41 PM
  #127
FastCat's Avatar
I keep seeing this white g slammed on gold volks makes me want to get a g35 coupe so bad.
Old Oct 20, 2012 | 01:42 AM
  #128
Big Booty Trudy's Avatar
Whats up guys. Looking to buy my stances here in a few days. Any advice y'all would like to give? As to which ones to get or so? Think I'm going with the true coilover setup. Never plan on tracking the car, just for looks, comfort, and maybe stancing it out one day when I get wheels (hopefully). Any advice is much appreciated.
Old Oct 20, 2012 | 03:16 AM
  #129
Shanes_G's Avatar
Get higher spring rates in the rear
Old Oct 20, 2012 | 08:44 AM
  #130
I just bought stance GR+ 5k/12k spring rates. Absolutely love them and they go LOOOOWWW. Ride quality is great. My g is slammed and I've only used about half of the available thread on the coils. If you maxed out stances the Frame would literally be on the ground and the car would not move lol.
Old Oct 20, 2012 | 10:17 AM
  #131
OBsessed's Avatar
True rear coilover setup with stock spring rate, no where near maxed out. I'll have the wheels off later to do some fender work and will take a pic of the coilover while I'm at it, but there's a ton of room left for adjustment.
Wheel lip is currently just under 1.25" from the fender and if I remember right I've got about 2.5" of drop left on the coilover (on a 19" rim, you wouldn't be able to move fully dropped).
Old Oct 20, 2012 | 10:31 AM
  #132
OBsessed's Avatar
Actually, they've settled again, I'm right at 1" lip to fender now.
Old Oct 20, 2012 | 10:56 AM
  #133
Shanes_G's Avatar
Maxed
Attached Thumbnails anyone slammed to the max on Stance coilovers?-image.jpg
Old Oct 20, 2012 | 10:58 AM
  #134
Shanes_G's Avatar
Lek, what are your offsets?
Old Oct 20, 2012 | 11:35 AM
  #135
OBsessed's Avatar
Rears are 19x11.5+2, 255/35s. Going to pull the fenders as much as I can today (only rolled, no pull except what was caused by rubbing) and then look into larger outer lips if it seems doable.
Edit: Ideally I think I want to go with some new outer lips, move the current rear lips to the front and run something stupid if I can pull off the fender work and limit the amount of negative camber needed. I don't know that will happen, but it'd be nice.
