RRYDE Custom Engine Bays
Old Apr 17, 2012 | 01:18 PM
  #541
CandlestickPark's Avatar
ill Sedan
^I'm almost positive you'll need an aftermarket radiator to do so and it invovles welding AN fittings (and welding coolant pipes too)
Here are my modified coolant pipes.
Old Apr 17, 2012 | 01:21 PM
  #542
TORETTO's Avatar
Ahh. Well thats one reason to go with a new rad.
So all you did was weld shut the sectionss that were used by the bypass line? So the extra set was just sort of like a back up incase you wanted to go back or messed up.
Any issues with deleting that bypass line? or all is good?
Old Apr 17, 2012 | 01:33 PM
  #543
ill Sedan
Yes the parts that are connected to the bypass hose were welded shut. Also an unneeded bracket was chopped off. I needed an extra set of pipes because otherwise I would have had downtime on my car while the pipes were being welded and chromed.
No issues with deleting the bypass line, it just takes longer to bleed the coolant system with the line removed.
Old Apr 17, 2012 | 01:36 PM
  #544
JBF's Avatar
JBF
I have a set of coolant pipes. PM me.
Old Apr 17, 2012 | 01:37 PM
  #545
G35CDriver's Avatar
omg Marcus, those lines are sick! I am sending out my spare set to have them done in the manor.
Old Apr 17, 2012 | 02:35 PM
  #546
outcasted g's Avatar
nice! thanks Marcus! im gonna tell randy to run mine through the radiator too
Old Apr 17, 2012 | 03:00 PM
  #547
lsmooth81's Avatar
Originally Posted by ME GUSTA
thanks marcus. I might just run it through the radiator.
Can alf or lou post up some pics of their setup or explain what they did?
Here is the link showing my coolant line welded to the radiator
https://g35driver.com/forums/6349274-post410.html
Old Apr 17, 2012 | 03:07 PM
  #548
jumbaco's Avatar
Originally Posted by JBF
Any tips for cleaning up my FD's engine bay?
there's a good amount of slask in the harnesses. You may need to cut some of the wrap and redo it but you should be able to hide a lot of clutter. I can help you out with it sometime.
Old Apr 17, 2012 | 03:17 PM
  #549
ill Sedan
Nice Lou. I didn't realize the pics I took showed the welded line.
Old Apr 17, 2012 | 05:42 PM
  #550
RRYDE's Avatar
To do it like Lou's and Alf's, you need to use an aftermarket radiator. A fitting is welded to the radiator and a fitting is welded to the driver side coolant pipe, and the passenger side coolant pipe is welded closed.
Old Apr 17, 2012 | 06:32 PM
  #551
sounds like a lot of work i think i just might run the hose over the top like Marty's
Old Apr 17, 2012 | 07:23 PM
  #552
TORETTO's Avatar
Thanks for the pics Lou & Marcus.
I'll probably do it Marcus' way when I get to that point.
I just tucked the passenger and driver loom today (i'll tackle that passenger alternator cable tomorrow or something)
Yes. I need a rhd batt cover.
Old Apr 17, 2012 | 07:48 PM
  #553
ill Sedan
That setup still has AN fittings welded Chris. As long as you have the coolant lines and your radiator hasn't been installed yet its not hard to do.
Old Apr 17, 2012 | 07:55 PM
  #554
SxExCx's Avatar
Samco now makes silicone pipe caps which will outlast the car. They might not look as clean but it is a much easier mod than welding.
The caps are hard to find but they are out there.
Old Apr 17, 2012 | 09:00 PM
  #555
alfhasg35's Avatar
to do the bypass coolant line mod is not cheap... with radiator, welding, fan shroud, spal fans, various hoses and fittings, chroming and polishing and scheduling time and labor i'm in it about $1500... give or take.. more giving though...
