LS1 Drift Build 'Nuff Said'
#257
And the motor has not been fired yet... Car is coming home from fab work and I have to get it ready so I can paint the bay, cage and interior..
#261
Okay boys and guys, its pic time.. So this past weekend I went to go pick up my car from UpRev, from all the FAB work being done.. Cage, front tube chassis, Radiator ducting and much more... I love the work that Russell did and highly recommend him to anyone that needs any FAB work done on their car.
Now it sucked driving back cause it started to rain, tried to cover the car with a car cover so must of the exposed metal did not get rain on it.. But **** happens and water got on some of the metal so have to clean the rust off before paint..
I will add a drink later, at work so I forgot to upload a beer for the week..
On to the pic 80+ of them....lol
So my baby is finally home and ready for tea down so I can start getting her ready for paint...
mean mugging already...
Showing the Splitter from underneath..
Even my dog approves....lol
Yeah def going to be changing out the yellow for RED...
So I placed my old bumper on there to see what it would look like since I am bouncing around the idea of both bumpers. I think it looks good also.
And yes it is beat up a lot... But this just give you an idea how it would look.
Looks so mean..
Russell added some extra support bars to the bottom of the tube chassis.. No moving here..
Anther view of the bottom bracket support tube
PS Cooler mounted up and ready to rock
Its small but its all I need
Def going to change this to Red..
Hood pins installed, just awaiting my new hood
Here is my Headlight brackets, Russell did a pretty cool job on them.
another look
Good by ABS system.. Why? "Because Race Car!!!"
T fitting for the front brakes
Here is a pic of my Tank that will run all my coolant lines..
Door bars.... Now i have to remove all the stuff from the door and make some custom Carbon Fiber covers.. going to look good
Love this view. You get an idea of how everything looks..
Russell add these bars to protect my little/big head... lol
Base plate for door bars and front hoop
Base plate for main hope and door bars
Its a party over here.....lol
Rear base plate
dash Bar complete need to trim dash some but you get the idea
Pic of the ASD Hydro mounted
Hydro all wired up
The T for the rear brake lines. I love that they run through the cab. Easy fix when something goes wrong
Sits a lot lower then my old bride rails did and I love it..
Man looks so legit from this view
I really did not get a chance to showcase the Ron Davis Radiator so here are some pics..
Ron Davis knows their stuff and it shows with the 35 years of experience
Radiator Ducting looks so legit
Here is the splitter, kind of dirty now due to the rain, but will be painted black anyways.. Also I am going to make a ton of copies of this just in case I F it up..
Thinking of doing a alumacore one and a CF honeycomb splitter..
Splitter bracket. also have about 4 other mounting point..
Head lights out..
BAM!! ready to take out engine again, but first I have to run my throttle cable to check length.. That will be next week.
Again here is a shot of the Headlight brackets.. love the wholes...lol
Okay now for what everyone has been waiting for the price break down for all of this. Now remind you this price can change do to metal prices, your build labor price, and if you get a hook up.. just so you know.
Formula Drift 1.5x.095 Wall Legal Cage 2011 $1200
Dashboard Fitting/Installation $0
Additional Bars (partial sponsorship) $110
Remove Rear Parcel Shelf $300
Front Tube Frame $850
Powersteering Cooler Bracket/Install $0
Ron Davis Radiator (partial sponsorship $600
Radiator Ducting $200
Radiator Installation / Fabrication $50
Coolant Expansion Tank inc fittings/filler neck $300
OMP Tow Hook $40
Hydraulic Handbrake Fabrication $125
Driver side Seat Bracket $175
AN Brake Line Installation $250
AN Line Materials Hardline + Soft Line + Fittings $150
TOTAL $4350
Total price so far: $14,447.16
Looks so mean..
another look
Rear base plate
Hydro all wired up
Head lights out..
OMP Tow Hook $40
TOTAL $4350
The following 2 users liked this post by Royal_T:
JaE35 (12-13-2011),
redpearl99 (01-07-2012)
#264
Yup time for me to a tubular front on the G Sedan. After seeing how much room you freed up Im positive i can fit a front mount single turbo in front of the LSX water pump and still have room for a condensor for AC and with one of out tucked radiators it will be have the size of the one you are running.
If you want to get rid of that booster we have a brake booster eliminator kit that will work perfect in that spot. I plan on getting rid of the sedondary firewall like fueled racing did with their 350z and not having any lines with our brake booster eliminator so the master cylinder will be the only thing you see.
#265
Nice, I plan to run a twin turbo setup later, but for now this will work..
Also I am getting rid of the secondary fire wall now as we speak.. I was advised against going with the brake booster eliminator though. A lot of drifters told me now to..
#270
Wait so they are saying to do it now? If so let me know ill get you one. The single outlet ones we use are a 7/8 's and will work perfectly with the setup that you have. The drifters are prob using the wrong master cylinder so they have the wrong pedal ratio. If you need one PM me for a sweet price
