G35 ls2 swap so cal
G35 ls2 swap so cal
Hey guys i live in so cal and i am looking for a shop to do a ls swap and knows what there doing. I have been told by a couple shops that they could do it but when all said and done they back out. So I need a serious shop who would do this swap. If there is anyone that can recomend a shop or shops id appreciate it
If you can find a shop that does LSX work they should be familiar with the LS motor and be able to complete the swap. With the help of fueled racing for the swap kits and chasebays for a wiring harness you shouldnt have a problem having any competent shop do this swap. I was able to do it in my garage. Heres a link to the build thread i did https://g35driver.com/forums/g35-sed...-lsx-swap.html
^ if you guys were in Vegas I could def help you. But what like brew_haha said their harness from chasebays and fueled racing kit it's pretty much a straight forward swap for a competent shop.
Oh and I strongly suggest the chasebays harness, it's clean and will save you any headaches you may end up with,most likely will, if you try another route harness wise.
