DIY: Airbag Reset Instructions for 03-07 G35 Coupe
Old Jul 21, 2013 | 12:28 AM
  #151
3rdG's Avatar
Bought car (05 Coupe) today and after 200 miles the light came on. Will attempt the reset tomorrow.
Old Aug 15, 2013 | 02:20 PM
  #152
jonsg35's Avatar
Thanks g35man04!
Still valid DIY, worked on my 06 Coupe.
Old Aug 15, 2013 | 06:54 PM
  #153
3rdG's Avatar
Reset worked. Came back on a couple hundred miles later...reset again.
Old Aug 23, 2013 | 09:27 PM
  #154
socal black g's Avatar
Hell yea worked perfectly for me thanks so much!!
Old Sep 2, 2013 | 07:51 PM
  #155
SAMzG35's Avatar
G35
Worked for me today as well! Thanks.
Old Sep 5, 2013 | 11:57 AM
  #156
XpL0d3r's Avatar
Originally Posted by SFLG35
this is a little easier
To reset the light simply turn the iginition to the on position, (you dont need to start it). All the lights should stay on for thier diagnostic check. As soon as the airbag light goes off, before it starts flashing, immeditatly turn the car off. Repeat this 3 or 4 times (turning to on then off) and the light should go away
This worked perfectly for me the other day. Anyone know why this happens? I brought my car in to have a window motor replaced. Picked it up, turned her on and the SRS light was flashing.
Old Sep 23, 2013 | 05:47 AM
  #157
norcalG's Avatar
So I removed my seat to clean carpet in my g after I put it back together I noticed the air bag light was flashing I did this trick and it stopped thank u guys
Old Mar 24, 2014 | 11:39 PM
  #158
Moonn's Avatar
I took passenger seat out to remove door panel to replace frozen door lock. Anyone know is reset procedure is same on 2008 G35x?
Old Apr 12, 2014 | 05:07 PM
  #159
Santis_G's Avatar
Thanks SFLG35! Worked for me!
Old Apr 26, 2014 | 03:45 PM
  #160
twenty5's Avatar
works great! Thanks!
Old Apr 29, 2014 | 02:54 PM
  #161
rcriley's Avatar
This worked great for me! Thanks for the post...I'm sure you saved me big $.
Old May 2, 2014 | 08:45 AM
  #162
ohfive's Avatar
My airbag light recently came on and i Did the reset and it worked well for a few days, now it just comes back on every few days after I reset (flashing)... I no longer have warranty and just wanted to know if anyone experienced the same issue.
Old May 2, 2014 | 09:11 AM
  #163
jsm11482's Avatar
It probably means there's actually a problem!
Old May 2, 2014 | 09:40 AM
  #164
ohfive's Avatar
I figured that. Just wanted to know if anyone experienced the same problem and wanted to hear from them.
read the bottom of my post kthx
Old Sep 14, 2014 | 09:12 PM
  #165
erikill's Avatar
More good luck on this car this year:-/
So this morning when heading out for the day I noticed the SRS flashing. Came home tonight tried both resets to no avail, however now it is 2 fast blinks then the pause. Anyone know what that means a failure of (or if I can pull w a plain jane OBD2 reader? I did install the DD kit about 4-5 months ago but no issues until this morning. Thanks in advance.
You have already rated this thread Rating: Thread Rating: 4 votes, 4.75 average.
