Reviews Reviews of specific modifications, posted by members
Unichip = Best N/A Mod ever
Old Sep 25, 2006 | 01:21 PM
  #76
ChicagoX's Avatar
Don't drink and Mag Race
Did you guys honestly believe ANYTHING coming out of gaytrain's keyboard?
BS, BS , BS. For years now.
Maybe I'll break out the pics of him thugging it up in Guatemala with his wittle knifey......
Old Sep 25, 2006 | 04:56 PM
  #77
FI'ed G's Avatar
Originally Posted by fortified
It's not clear to me if you got 13hp MORE after the chip, or got 13 with everything including the chip!
Don't get me wrong! I'm just skeptical about how much good the chip does after you do everything else. Basically, your first setup before a chip, and then after a chip. That's what I would like to see.
Because if you did if you go to the link, the two G's that don't have a chip are pushing 260 whp, so if they have your good experience they should be pushing more like 270 with a chip. Unless someone screwed up and forgot to add it to the list of mods.
I'm running a Z tube, Stillen air box, and a 5/16 will be next. Then I am looking at exhaust. Just looking for now until I learn more about exhaust as well as reflashes or piggy-backs.
Adding an EMS with Tune will definitely add 10+ WHP on top of what ever Mod you already have, and it does add power across the power band and not just peak. I say don't be skeptic coz it's been prov-en already. The only problem with adding an EMS is the cost of the unit and the Tune. If I'm not mistaken there is a Dyno of someone in My350z that did gained 15WHP with only ZTube/K&N filter and Utec (with aggressive Tune).
Old Sep 25, 2006 | 06:38 PM
  #78
fortified's Avatar
Well, I have a 5/16 spacer now, along with the intake changes. It sounds like going the chip route would be next. I don't know how long (or if) it will be before I consider changing anything else. Thanks for relating your experience.
Sounds like UTEC or Unichip are the most proven ones. maybe TS.
Old Sep 25, 2006 | 10:53 PM
  #79
V35 Skyline GT's Avatar
6MT Coupe
I have no doubt a chip will increase hp/tq. It's already a proven fact.
Know a guy who running one on his G. Yeah more hp/tq across the entire span and about 15-18 mpg tops (in granny mode).
I just get bothered with ppl who claim excessive gains (300+ hp and still only NA), said they dyno'ed and won't post results/proof of what they claim.
[request]:unsubscribe from post
[command]:enter
[request]:completed
This post is a complete waste of server space...heh!
Good Bye
Old Sep 26, 2006 | 01:13 PM
  #80
fortified's Avatar
[command]:enter
[request]:completed
Good Bye
So you are saying even without your foot in it all time, mileage will drop with a chip?
Old Oct 11, 2006 | 09:33 AM
  #81
beholder's Avatar
Originally Posted by partyman66
There is no way you have 302 wheel HP from just those mods. That sounds about like what you'd be expecting to get at the flywheel after those mods(not the wheels), considering that the 04' G35 Coupes were rated at a very generous 280 crank HP(overrated according to our current SAE standard, since they were dynod by Nissan without any auxillary components hooked up on the motor... resulting in higher HP/Torque numbers at the flywheel when they achieved the supposed 280 HP number).
In order to get 300+ wheel horsepower out of a N/A G35.... especially in an Auto tranny(more parasitic drivetrain loss in the Auto Tranny than the 6MT), you'd need to either go forced induction or at least go with aftermarket cams and a mostly built motor(higher compression pistons, etc) in addition to the other mods you already have.
A stock Auto 04 Coupe usually gets somewhere around 215 to 230 or so WHP. A 6MT gets anywhere from 225 to real low 240's for WHP according to most dynos.
To expect to gain 80 WHP from a N/A engine that is already highly tuned from the factory by just doing breathing mods, a set of pulleys, and an ECU tune is highly unrealistic. My guess is that you're probably at around 250 to 260 WHP max with your current mods.
Agreed.
Old Oct 12, 2006 | 02:14 AM
  #82
madscientist's Avatar
Originally Posted by G-Tofu
did you mean 230hps with those mods?
I have everything rev-up motor, PULLEY, MREV+, Intake, HEADERS, Cats, dual exhaust, UTEC and TUNED (by Turbo SX) and I only made 285hp to the wheel on DYNO-PACK....
so what did all that engine work run you?
I mean, that's GOTTA be close to the price of low end FI, right?
Old Oct 12, 2006 | 02:25 AM
  #83
anDross's Avatar
Is Jtrain going to provide a sheet? I'm sure he's a little embarassed about the whole situation. Oh well.. if he's lying he's lying. However, I don't think he's lying.. I just think that he misread the sheet and is afraid to admit it.
Old Oct 12, 2006 | 09:10 AM
  #84
g35rcr's Avatar
all it takes is a dyno sheet...but its as real as his ideas about his car
Old Oct 12, 2006 | 12:08 PM
  #85
vt_maverick's Avatar
^^^ Bump for this answer. I buy into the fact that a chip will increase HP/TQ, but as they say in economics, "there's no such thing as a free lunch." The stock ECU came out of the factory programmed a certain way - there's got to be something lost when you re-tune or else Infiniti/Nissan would have programmed it that way when it rolled off the line. Right? Wrong? Crazy?
Old Oct 12, 2006 | 12:33 PM
  #86
fortified's Avatar
That's fair. While it may cost sales, chip makers/falshers should be upfront with mpg data too. I think I speak for most of us when I say we like power when we need it. So I am not sure sacrificing mpg during cruise is worth the power when you hit it. That's a personal decision.
The trade off is not always the same. Better breathing can yield more power and might even gain 1 mpg because of it.
So I am not sure the programming can not be tweaked to only offer power under demand. For example, the limited Technosquare flash which only raises the rev limit, and opens the throttle max at WOT.
Old Oct 13, 2006 | 05:42 AM
  #87
drunkin master's Avatar
i have full catback exhaust, test pipes from fast intentions, 5/16 spacer, ztube and k&n drop filter. Had a dyno done and got a constant 236 to 239 rwhp. I put up the dynos to prove that fact. I have a 5AT 04 coupe.
Reading through this thread and still not seeing a dyno from this guy just proves that facts.
Old Oct 13, 2006 | 11:01 AM
  #88
Damn dude, that's kind of depressing when you compare those numbers to these: (somebody posted this earlier in the thread, can't remember who)
http://www.gurgen.com/clint/G35/2004...9_04_2004.html
Not trying to be a d!ck, but am I missing something here? It seems like everything you added should have made a decent increase, but it doesn't bear out against the numbers in the file. Maybe the dynos were different - the one in SoCal being optimistic, yours pessimistic?
Old Oct 13, 2006 | 11:39 AM
  #89
g35rcr's Avatar
i think he figured his v-tec sticker added 30 hp
Old Oct 13, 2006 | 11:59 AM
  #90
D's06G's Avatar
hey how do u get the chip?
