UR Crank Pulley
Originally Posted by qmaster8
Did none of you guys worry about voiding your warranty by installing the underdrive pulley? It is the only mod I am doing that is directly related to the engine and that could maybe cause serioud problems if something went wrong.
I want to get the Black colored pulley so maybe the dealership won't be able to notice it when they do oil changes and the like.
Is it really worth it? If you live in Houston, what dealerships do not care about mods, as I usually goto Southwest Infiniti as that is where I bought the car.
Thanks.
Jason
Thanks.
Jason
Having read about all the happy members who have done the mod, I now wouldn't hesitate to do it myself.
I did discuss it with my dealer tho. who agreed with the mod and would have assisted with the install.
C.
Originally Posted by bunnone
Say it ain't so! Why are you selling the coupe GSM?
So, he's now going to go back to a sedan, but because of psychological childhood (family-of-origin) issues, etc., he'll likely end up with a 'M'! This would answer his coupe-sedan dichotomy, and since the G-M issue isn't as significant (at least at this stage), the associated guilt issues are attenuated by the likelyhood that he'd stay on here.
Make sense?
Originally Posted by gordgee
He's always had an issue with being called gsedanman, since he drives a coupe.
Make sense?
Make sense?
Only Gord could have put it quite that way. Kudos on your eloquence, bro
Bunnone, I've had G's now for nearly 3 yrs. It's been great, but it's time for a change. This will prolly happen early next year.
Not a big change mind you,-- the M I'm thinking of is very similar to the G-Sedan that started it all for me (and many of us). It'll have a few more toys on it and more power (V-8) and I'm looking forward to it very much.
I've got fond memories of both G's and have learned so much from everyone while sharing them with all of you.
I'm hoping the M lives up to the Infiniti name as the G's have.
I'm not going anywhere, BTW, so I can still share your G's with you, as well as my M with you.
Sorry to go so far off topic (not setting a good example am I) but bunnone's has been around for a long time, and deserves an explanation.
Colin (GSM)
UR Pulley
Originally Posted by gsedanman
With the 6 speed it's easy. Just put it in gear and have someone apply the brakes.
With the automatic it's a little more tricky, unless you have an impact wrench available.
Apparantly there is a small access cover by the ring gear (not sure if it's on the starter side or other side), that when removed will allow a locking bar to be used to engage the ring gear to stop its' rotation.
What idea did you have?
06g35
Feb 14, 2022 05:59 AM
brianuc4
19
Apr 10, 2020 02:12 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
