Reviews Reviews of specific modifications, posted by members
Stillen Swaybars
Old Aug 24, 2006 | 07:27 AM
  #61
Dan_K's Avatar
Tanabe makes a rear only sway bar.
http://www.speedtechnique.com/tanabe...m-p-22833.html
Old Sep 28, 2006 | 08:51 PM
  #62
jetblackg35's Avatar
Just put my Stillen sway bars on my whip, man what difference now. I did the med. setting in the front and the stiffer setting in the rear. I went with the stiffer setting in the rear cause my car is rear wheel drive and my Infiniti tech told my that was the best setting for my car. Just thought I give my 2 cents.
Old Sep 29, 2006 | 08:29 AM
  #63
g35rcr's Avatar
all our cars are rwd
Old Sep 29, 2006 | 08:46 AM
  #64
Ya I know I walked right into that!!
Old Oct 5, 2006 | 08:46 AM
  #65
rcdash's Avatar
I complained about the rear axle tick and on a completely unrelated note the dealer noticed the upgraded sways and asked if I wanted to upgrade the endlinks (for free under warranty). Ummm, you can guess what I said.
I have mine set to med/med and it still has slight understeer but much more neutral; oversteer can be induced easily with throttle control.
You guys are certain that the hole closest to the bar is the stiffest setting, right? I was thinking of trying that in the rear.
Old Oct 6, 2006 | 11:19 AM
  #66
Gordgee's Avatar
Administrator
I ran all summer with the rears at the stiffest setting. I found that traction in the rear was significantly compromised, especially when accelerating out of corners, or hard out of even gentle turns!
My second set of OEM end-links wore out, and I installed the new OEM end-links back at the 'mid' setting.
Though body sway is a little more, it's not significant. But the big change is in the handling. The rear seems less 'antsy', and has a more fluid feel and movement in turns. Traction is much better now.
At least for me, the medium setting on the Stillens works the best.
Old Oct 6, 2006 | 12:44 PM
  #67
RRG35's Avatar
changing the sway bar front and back does it help or can you tell me what improvement will it do to my g35 coupe??
Old Oct 10, 2006 | 07:36 AM
  #68
rcdash's Avatar
Hmmm, maybe leaving the rear at medium and moving the front to soft is a better thought...
Old Oct 10, 2006 | 07:27 PM
  #69
Gordgee's Avatar
Administrator
If you want a bit less understeer, that would be the way to go. Remember, you can also experiment on intermediate settings with by using one hole at 'mid', and one at 'stiff' on the rear as well. Try the front at 'mid' and soft'. If you have time, just play around, experimenting on the settings.
Old Oct 18, 2006 | 04:27 PM
  #70
gwasabi's Avatar
would it eliminate understeer in the front if I put the sway bar at med in front and stiff at back. I like oversteer but not so much that i would oversteer out of every corner
Old Nov 11, 2006 | 05:47 PM
  #71
cutiewolf's Avatar
my rims r 19x8.5 19x10.5 with 285 tires on
im getting a set of stillen sway bar...how much should i get it for the front and rear? i like cornering hard on streets and sometime making a U turn i like to drift it. help me out guys thanks.
Old Nov 13, 2006 | 02:15 PM
  #72
bull3t's Avatar
can you notice a difference when you're switching lanes or aggressively switching lanes?
Old Dec 1, 2006 | 11:15 PM
  #73
Hydrazine's Avatar
Agressively and you will.
Picture Share
Feb 4, 2018 12:41 PM
Video Share
Jan 31, 2017 04:00 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
