SFL G CLUB South Florida G35's + G37's
dm2 motorsports oil cooler
Old 06-27-2008, 08:06 AM
mushy's Avatar
dam mike your a master wielder
  #32
Old 06-27-2008, 10:02 AM
rpm06g35's Avatar
Nah bro I dont weld. I just fabb everything up and design all the stuff to be welded. If I could weld it would be all over. But anyways yes my guy can def lay a bead down.
  #33
Old 07-08-2008, 02:04 PM
rpm06g35's Avatar
update on the pressure test. Welp what can I say both of them failed. pinhole leaks all over. In the process of touching up the welds then we will dunk tank to ensure they are air tight. One of them has a for sure leak in the core itself. I think that was caused by lack of knowledge of proper usage of a pressure tester. Lets just say I ran pressure up to about 80lbs and ernest and I are lucky to be alive. It goose egged the end tanks. But it still held together. I will keep you posted.
  #34
Old 07-09-2008, 05:18 PM
rpm06g35's Avatar
It took 3 pressure tests to come up with a 100% no leak guarantee. After full dunk we have our first successful oil cooler. It held 35lbs for 30 minutes. I will bring it out friday as well.
  #35
Old 07-27-2008, 12:20 AM
rpm06g35's Avatar
installed will post more pics later
  #36
Old 07-27-2008, 01:42 PM
escobar929's Avatar
nice mike, that thing is huge!
  #37
Old 07-27-2008, 03:47 PM
mushy's Avatar
^^ hahahahahaha, that's what she said
f22raptor
03-18-2016 08:50 AM
mbe32
11-13-2015 11:09 PM
dseet
10-11-2015 12:40 AM
9tray turbo
09-29-2015 10:22 PM
Quick Reply: dm2 motorsports oil cooler
