WTF -- Complain of Second Gear "clunk" and now can't engage!
Old Feb 4, 2007 | 08:36 PM
WhiteonWheat's Avatar
Angry WTF -- Complain of Second Gear "clunk" and now can't engage!
I went to stealership for a scheduled oil change and complained to 'my guy' that I keep hearing a nasty "CLUNK" noise when shifting into 2nd gear.
[By the way, has anyone else experienced this??]
Anyways, they gave me the car back and said that they have a TSB on the 2nd gear issue and that it called for switching out the tranny fluid to synthetic.
Now my driving experience is horrible. Sometimes (1 out of 3 times) I can't even get into first gear! People around me are looking @ me like I'm an **** for sitting at the green light so long. I've got the clutch pile drived into the floor board and am shifting into first and hitting a brick wall, backing back out into neutral and trying again and again. When I finally get into 1st, it feel like two pieces of rubber are rubbing really hard against each other and then POPPING hard into place (1st gear fully engaged)
The pressure I have to put on the gear shifter to finally get it into 1st, is way to forceful!!! It's ridiculous!
Sometimes, I experience the same w/ 2nd gear as 1st. It's like something is not aligned right? Maybe the "GUIDE PLATE" is off or something?????
THE REALLY WEIRD THING IS SOMETIMES IT TOTALLY GOES AWAY.
So basically, sometimes it's doing what I described and then other times it's totally fine. The exception is the CLUNK going into 2nd gear. That NEVER goes away!
I guess if I had to think about it, the warmer the tranny is (car being driven for a bit) the better this issue is, again except the clunk.
I've already called and told them this WILL BE RESOLVED!
What is the group's .02 on this?
Thanks Guys!
-WoW
Old Feb 4, 2007 | 08:47 PM
Rphillips6487's Avatar
Ive never expeirenced that and to my knowledge no one else has.
as youve already done, take to the dealer, have them drive it and see what your talking about, itll be covered under warranty so itll be resolved
good luck
Old Feb 4, 2007 | 08:49 PM
Beebo's Avatar
me neather
Old Feb 4, 2007 | 10:02 PM
AAClaire420's Avatar
well sometimes it is tough to shift my car into second........I thought it was me ****ing up while driving but after reading I guess a lot of people have this problem.....
hopefully its nothing serious like yours...man that sounds like it sucks
let me know what happens when you take it back to the dealer
Old Feb 4, 2007 | 10:23 PM
BrocksG's Avatar
ah you'll get a new tranny!
Old Feb 4, 2007 | 10:59 PM
JSpec350GT's Avatar
My tranny makes noise during shifting from 1st to 2nd. It sound "Cluck" while I force it in the second gear. I'll talk to service person in the next schedule. Hopefully, nothing major.
T
Old Feb 8, 2007 | 07:05 PM
Arrow
*Update
I'm taking the car in for the service tech's to take a look @ this coming Monday the 12th.
I'll post the results.
Man, you guys have me terribly worried ("Ah you'll get a new tranny"). I guess a new tranny would be good, but it's only got 23K on it....
By the way, is there ANY way to double check and make certain of the accurate mileage on a car other than the cluster?? I guess it's all stored in the ECU right? Hmmmm, I hope my car really does only have 23K on it, LOL!
That would suck if it was tampered with.
Old Feb 8, 2007 | 07:19 PM
GreenGoblin's Avatar
The goblin resurrection
ya that would suck I am not sure how people roll back mileage I think that it is stored in the cluster not the ecu
Old Feb 8, 2007 | 08:08 PM
BadBoy06's Avatar
+2 strange stuff
Old Feb 11, 2007 | 12:18 AM
Zoom750's Avatar
I had a similar issue after getting the 30k mile service. Difficulty shifting into 1st and 2nd, with gear whine, especially when the car was cold. However, it does not appear to be as severe as your experience. Dealer kept the car for a week. They did not say exactly what was done, but it seemed they were constantly changing the fluid, based on my conversations with the service rep. Final resolution appears to be different tranny fluid. If I remember correctly, they used 75w90 viscosity. There's still a slight whine with the current cold Northeast weather, but it goes away when the car warms up. It's been about 1k miles so far.
Old Feb 11, 2007 | 03:15 AM
TwiBlue's Avatar
Its stored in the cluster not the ecu. gl with your issues
Old Feb 16, 2007 | 12:55 PM
* Update!
https://g35driver.com/forums/g35-coupe-v35-2003-07/140116-need-02-s-like-now-new-tranny-going.html
mattdg35
Sep 14, 2015 11:28 AM
UndyingDest
Drivetrain
Sep 7, 2015 12:49 AM
