Oklahoma G35/Z Owners Roll Call
Hmm so you only gained around 14/15 from the tune.. Its good gains but none the less sounds a bit disappointing when compared to those other guys that get it tuned in cali and such. From all the graphs and threads i read they all usually get around 20tq or something..
Is it possible because the guys at failsafe are newer at tuning these?
I'm sure Chris will chime in with further info.
Yeh different dyno's read differently but that shouldn't have to do with how much gains you get from the tune. Because the gain number should be the same right? Just the TOTAL result will be different compared to different dynos.. correct me if i'm wrong.
But yeh the heat probably had something to do with it too.
Well heres the g35 shirt i was talkin bout guys
http://www.motosector.com/main.htm
The dudes name on this forums is "neight"
