FS[SoCal]: UAS Air Suspension
Old 02-08-2013, 07:35 PM
ShanesG's Avatar
UAS Air Suspension
Alright so finally got some free time to finish taking out my air ride.
So for sale i have a complete used UAS air system.
What's included:
>All air lines (Have all been upgraded to soft DOT lines with screw on fittings)
>8 Valves, 2 per corner (Half of them stick sometimes and just need to be cleaned.)
>Dakota Digital guage(I am going to include the complete auto shifter cover where i have it mounted)
>7 Switch switch box (older style, much nicer and better quality)
>1 Viar compressor(one went out, although i only used 1 anyways since i rarely aired up)
>5 Gal tank (normal wear and tear and scuffs on it but still nice)
>air bags for all 4 corners, the fronts are attached to the strut already and will be included)
>All the wiring, i made sure not to cut anything so you can reuse all of it.
The Bad:
The valves do need to be cleaned. I don't have the time to do it which is the main reason i'm listing this for pretty cheap
I would also cut about an inch off each end of the air lines as some air would leak out. Although IMO it's from the valves needing to be cleaned.
That's really it, everything is still in really good condition.
I just realized i forgot to take pics of the actual bags, but we all know what they look like haha. If you need a pic though lmk and i will take one.
Price: $1500+shipping
Open to trade + Cash for GoPro Hero 3 Black edition
Old 02-08-2013, 07:54 PM
b-dRizZy's Avatar
dayyaaammm hurts to see this go away. !.
GLWS Shane
ShanesG (02-08-2013)
Old 02-08-2013, 08:54 PM
GARRYDG07's Avatar
GLWS homie
Bump for a legit set up
Old 02-08-2013, 08:57 PM
Shanes_G's Avatar
So would I just take the springs off of my stance coilovers and put the bags on?
Old 02-08-2013, 09:19 PM
ShanesG's Avatar
^Yeah you can use any coilover setup, just would have to remove the springs. Rear bag utilizes the oem spring bucket, so if you have a true coilover setup in the rear you would have to remove it from the strut.
You would have to order 2 bottom brackets though through UAS because the current ones were welded to the strut.
Old 02-08-2013, 10:52 PM
Shanes_G's Avatar
What brackets? Are they welded to the front struts? Would I have to get then welded to my struts too?
Old 02-09-2013, 01:30 AM
Jaygotboost's Avatar
Bump for a legit set up, seen it in person!
Old 02-09-2013, 08:18 AM
serges's Avatar
Nice set up bump for a good deal!!
Old 02-09-2013, 10:23 PM
muhtish's Avatar
if i knew anything about AIR rides, I would probably know whats at stake here.
GLWS
Old 02-09-2013, 10:58 PM
ShanesG's Avatar
All the airbags have a plate that gets bolted on the top and bottom of the bag depending on what car you have. You would simply need to buy the 2 bottom ones. You don't need to weld them. That's how i bought the kit and never changed it.
Old 02-13-2013, 09:08 PM
ShanesG's Avatar
bump, ready for a new home
Can be used in most cars just would need different brackets for the bags.
Old 02-24-2013, 07:04 PM
ShanesG's Avatar
Air it uppp
Old 02-24-2013, 08:17 PM
bakwoods's Avatar
Very tempting offer. Will probably have money for this in about a month. If no one takes it I'll be happy to buy. PM sent.
Old 02-25-2013, 12:38 AM
gtrefever's Avatar
Pm sent. Shane text me!
Old 02-25-2013, 03:10 AM
ShanesG's Avatar
Sale Pending!
Quick Reply: FS[SoCal]: UAS Air Suspension
