FS: Power Steering Stuff
Old Jul 1, 2013 | 02:46 PM
bigc's Avatar
Wings Nation
Arrow Power Steering Stuff
* * * * * All items have been sold * * * * *
For sale are a few steering-related items:
  • Power Steering Tank and Bracket - GTM - SOLD
  • Power Steering Pump Pulley - SOLD
  • Power Steering Tank and Bracket - OEM - SOLD
Power Steering Tank and Bracket - GTM * * * * * S O L D * * * * *
New and unused. This tank provides more clearance around turbo kit charge piping. I will also throw in some black braided hose. $30 shipped.
Used, but its just begging to be chromed as part of your engine bay dressup! $12 shipped.
Power Steering Tank and Bracket - OEM * * * * * S O L D * * * * *
Used, but no leaks. Painted black, but a window is provided so you can check fluid levels. $25 shipped.
Old Jul 20, 2013 | 06:51 PM
guitarrocker98's Avatar
I'm interested in your black power steering pump. It's between this and a polished one. I sent you a pm on the hoses... How easy is the install of this?
Old Jul 20, 2013 | 07:57 PM
bigc's Avatar
Wings Nation
Crap, my bad. The black OEM P/S reservoir sold just before I went out of town so I didn't have time to edit the OP. Its been updated now. Will check your PM shortly.
FYI, installing a reservoir is strtaightforward but a little messy. It helps to use a battery filler to remove the fluid first (alternatively, you can clamp off the line to the cooler, pull the line off the hardpipe, then loosen the clamp to drain the fluid).
Old Jul 20, 2013 | 08:01 PM
Dang. Looks like I will need to find a polished one eventually.
Old Aug 5, 2013 | 12:39 AM
bigc's Avatar
Wings Nation
The power steering pump pulley has been sold.
The GTM power steering tank is still available.
Old Nov 11, 2013 | 12:10 PM
bigc's Avatar
Wings Nation
Old Nov 22, 2013 | 03:13 AM
laksjd84's Avatar
does the tank fit right on oem without modification?
Old Nov 22, 2013 | 12:49 PM
bigc's Avatar
Wings Nation
It slides on the OEM bracket the same way as the stock tank. The only difference with the tank itself is that one of the bottom ports points to the side as opposed to straight down. Not a big deal since the hose it connects to is rubber / flexible.
Old Dec 12, 2013 | 12:23 PM
bigc's Avatar
Wings Nation
Old Dec 14, 2013 | 03:56 AM
laksjd84's Avatar
I dont have oem bracket anymore. does this come with mounting bracket?
If so, i'll take it.
Old Dec 14, 2013 | 04:01 AM
bigc's Avatar
Wings Nation
yep, comes with the bracket.
Old Dec 16, 2013 | 04:07 PM
bigc's Avatar
Wings Nation
All items are now sold.
gatorglaze
Sep 10, 2015 12:03 PM
yosip1115
Sep 9, 2015 03:30 PM
Kicknshift
Sep 3, 2015 09:35 AM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
pasjr1972
Sep 1, 2015 10:17 PM
