FS[SoCal]: Suspension parting out/ BC Racing Coilover/Kinetix/SPC camber
I'm parting out my car and I'm starting with the suspension pieces:
BC Racing Coilover : SOLD
Kit has less then 9k miles on them and are in great condition...the only issue is I over-tighten one of the set screw on the extender and busted it. It is still secure to the strut in case you still want to use it if not it can be drilled out. This is just the screw that keep the extender attached to the strut and does not affect operation in any way.
Kinetix front camber : SOLD
SPC rear camber : SOLD
Rear Hotchkis Sway bar : SOLD
All prices are for pick up in the Lake Elsinore area.
No I used only the rear sway...I figured since I have the sport suspension and the front sway was only 1mm thicker than the oem I didn't buy the set. Most people that buy the sways end up using it on soft, which is only a 5% increase from the sport suspension sway.
FS[Texas]: KSport Air Suspension G35/350Z/M35
privatecorye
Steering & Suspension
May 31, 2016 01:56 AM
Fireman07603
Aug 9, 2015 06:00 PM
