TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Fuel tank shutter valve
Old Dec 1, 2008 | 04:27 AM
  #31
G35cTT's Avatar
is the shutter valve the fuel level sensor? I just recently having the same issue of empty light going on then only being able to fill 12gals
Old Dec 1, 2008 | 01:07 PM
  #32
ahussain's Avatar
i have this same problem, ill be on 1/4 a tank, and i try to fill up and its stops 2 gal in..., though if i fill up when my empty light is on, itll fill up fine no problem... odd i know
Old Dec 2, 2008 | 09:00 PM
  #33
DEMoLITIoN's Avatar
Originally Posted by Andy2434
Man, you seem to be having quite a difficult time in resolving the issue. I took my car in for the very same problem after having my car for only a very short period of time. The issue was remedied via the shutter valve TSB. I have not had any problems since that time.
Can you possibly go to another dealership, if one is close by? I hope you get the problem fixed soon. It's a royal pain to have to deal with that.
I had the same problem the first time i filled up. I went back to the dealer. one of the employees took me to the gas station and showed me how to fill it. Stick it in all the way, push down on the grip so the nossle rises in the tube. pull the lever. there wont be any interference. I though it was bull, but it seems to work. my friends have the same problem when they try to fill my car.
Dallsinghjr1
Sep 17, 2023 11:25 AM
g.spot
May 9, 2016 10:54 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
BradMD_96
Oct 6, 2015 09:31 AM
Hogbone
Sep 28, 2015 06:44 PM
