TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
window problem
Old 06-19-2007, 10:38 PM
jaedoggz's Avatar
window problem
did anyone else have a problem with any of their windows? my passenger side window sticks and i have to punch the door panels to roll it up. loose connection or crappy motor? the switches are good so maybe just loose wiring huh?
Old 06-20-2007, 12:59 AM
nghiars's Avatar
crappy motor.. fixed under warranty
Old 06-24-2007, 12:27 PM
jasoncham2003's Avatar
if you have to bang on the door panel to get it to move 9 times out of 10 it is the motor going bad and it is seizing up and the jolt get sit to move. Get a new motor.
Old 07-02-2007, 04:05 PM
jaedoggz's Avatar
thanks, did it happen to anyone else?
Old 07-11-2007, 09:23 PM
Blackbird V35's Avatar
its happening to my driver side window, its pissing me off. I have to slam the door to get it to roll up
Old 07-12-2007, 06:50 AM
MaDdFLaSheR's Avatar
happens to my sunroof
my driver side window only makes a cracking sound when it rolls up or down
Old 09-03-2007, 04:55 AM
russofire's Avatar
windows...
my 03 coupe,33 k like new...in the garage . don`t see rain etc...with 2 windows with faulty motors... spoke with infiniti... passed the warranty ...they won`t help . a recall is needed... it`s now a safety issue !!! Let`s all get together and demand a recall ...
Old 09-04-2007, 11:37 AM
kjgspot's Avatar
i second that emotion!!!!!!!!! we neeeeeeeeeed recallllllll!!!!!!!!!!
i
Old 09-11-2007, 09:41 PM
nyqueenz's Avatar
problem.. I have 03 coupe. the pass window dosent wanna go bck up. it happen last night but let it sit for about 20mins. worked again. tonight same problem now stuck in down position. What do I do, how much is it gonna cost to fix. If its the motor how much will a new one go for? Can I fix my self?
Old 05-18-2008, 05:45 AM
NISMO500's Avatar
you can fix it yourself if you get a manual. I had the same problem after i hit a bump the window works fine now.. I think the motor is about 170
Old 05-18-2008, 08:29 AM
g35man04's Avatar
CLUB MODERATOR
yeah my window lastnight (04 G35 Coupe) went down on the passenger side....got home to roll it up and nothing...waited for alittle while since it had done this before and it worked fine the lasttime....still didnt get anything after an hour..waited until this morning and still nothing..I am thinking that my motor has ate it...what sucks is that Infiniti is closed today since it is Sunday...any ideas how I can get the window back up? or will I have to wait until Monday to get it fixed? I dont think any normal autoparts store sells our window motors correct?
Old 07-30-2008, 08:23 PM
Kerrymdunn's Avatar
RECALL FTMFW!!!!!!!!!!!!!!!!!!!!!
Any government officials that we can contact...dept of highway safety....dept of interior. .....some of you guys work in DC right...anyone beuller
Old 07-30-2008, 10:07 PM
tdm racer's Avatar
For the sunroof problem you might have to reset the motor.
Try this: Open the sunroof completely ( you may have to press the switch multiple times until it's completely open ). Then press and hold the switch when it hits the fully opened position ( about 3-5 sec ) now close the sunroof the same way and hold closed for about 3-5 sec. retest the sunroof operation after doing that, it should work ok...
Old 12-15-2008, 09:48 PM
snakes1021's Avatar
recall my drivers side went out right before warr. was up then the passenger is acting up now with 77k so warr. is up. i want it fixed for free so recall that ****. i shoudl told them to replace them both at the same time
mike730
01-12-2018 04:25 PM
leo38cheng
11-12-2015 06:49 PM
cmesidewayz
09-29-2015 09:28 PM
gatorglaze
09-10-2015 12:03 PM
Jnm07
09-05-2015 01:16 AM
Quick Reply: window problem
