TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Noisy Window When Closed And Driving
Old Aug 16, 2007 | 03:56 PM
fzr's Avatar
fzr
This just happened recently, when I have my window closed fully and I drive I hear this creaking sound, like the window would be too tight/too high up.
When I put the window just a bit down(like 1mm) the sound it gone, seems my window went up a bit, how can I adjust this? My mechanic didn't want to touch this, he said see the dealer.
Anyone?
Old Aug 23, 2007 | 11:32 PM
gizsf's Avatar
Most likely you have to do a window motor reset. It's in the service manual which is also online here.
Old Aug 25, 2007 | 10:31 PM
express705's Avatar
my coupe does the same thing.. its the driver window..
then i pull it up, and it gets to the top, it goes pop.
Old Aug 28, 2007 | 11:19 PM
gizsf's Avatar
That pop is most likely your window popping the tab on the outer painted trim. Not good for your motor/regulator at all. It needs a reset, if your under warranty, go to the dealer and they can do it in a few minutes. If not under warranty, do the motor reset.
Old Aug 30, 2007 | 09:31 AM
gottarex's Avatar
Can someone link me to this TSB? I just did a search and I couldn't find it . My driver's side window creaks too and my passengers side makes a wierd pop when the window gets all the way to the top.
Old Aug 31, 2007 | 02:12 PM
gizsf's Avatar
Old Sep 1, 2007 | 06:08 PM
gottarex's Avatar
My car has 35k miles, should I just bring it over to the dealer?
Old Sep 3, 2007 | 02:38 AM
gizsf's Avatar
Since it's still under warranty, yup! They may end up replacing the motor for you.
Old Jan 19, 2008 | 02:09 PM
Kenny G35's Avatar
similiar issue
my 07' G35 has similar issues. When i drive, with windows closed, regardless of speed (worste when driving slow becuase engine is quiet) i have this annoying wind, hiss noise.
this issue has caused to 100percent HATE my car.
any help on this one?
Old Jan 19, 2008 | 04:59 PM
G37Rider92649's Avatar
Wh0o0a, every time i open and close my door I hear a creaking sound inside my door like it's pushing the window too far up! It's been happening for a while now, and I'm not under warranty!!!! Can someone show me how to reset it myself???
Old Jan 19, 2008 | 09:00 PM
Da-G-SpoT's Avatar
DO a window motor reset. Very easy to do, just remove the door panel and the reset button for the window motor is under a black circle tape. There are several spots where there is this "finish tape" so maybe youll be lucky and find it the first time around, if not, keep on trying until you find a small black button.
Once you find it you close your door and raise your window all the way. Make sure to not click the switch to the automatic open/close as it would do this reset incorrectly. Make sure YOU have to raise the window with your finger not automatically. Now thats out the way, press the reset button and while pressing it lower your window all the way. Release the reset button and raise your window all the way back up. Tada! you are done. Test it out make sure everything is ok. Good luck
Old Jan 20, 2008 | 01:22 PM
V35 Skyline GT's Avatar
6MT Coupe
All said above true.
FYI: If same condition, but w/o pop noise and with air whisling noise, means window not going up enough too. If reset doesn't work, like on mine it didn't even with new motor, it's the regulator out of wack and/or regulator gone bad. Just went through this experience. One dealer failed after 4 attempts. Went to another dealer, fix in one shot...replaced regulator and whisle noise gone
Jussaku
Interior
Jul 29, 2015 04:13 PM
will091195
Jul 27, 2015 09:19 PM
mjfenix
Jul 24, 2015 05:16 PM
Kal Hamm
Jul 24, 2015 08:55 AM
