TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
New TSB for incomplete fillup?
Old Feb 13, 2009 | 02:38 PM
Glycerine's Avatar
I had the problem about 6 mos ago where the G wouldn't take a full tank of gas. Only put in about 5 gals or and stop. On my 3rd visit back, got a tech that had heard on the problem with his daughter's G and said he needed to replace the spring. Did that and everything was fine for a while.
Happened again. Took it in today and currently they have the back torn out of it. Said there is a new bulletin (since i last brought it in) that calls for adding/replacing (unsure) a brass bracket back there to fix it. Has anyone heard of this one? 06 coupe
Old Mar 2, 2009 | 07:03 PM
jetdoc's Avatar
Join the crowd. My car is out of warranty by a few months, so I am out of luck.
Old Mar 2, 2009 | 07:15 PM
nghiars's Avatar
Originally Posted by jetdoc
Join the crowd. My car is out of warranty by a few month, so I am out of luck.
TSB Recalls should be in effect whether you are in or out of warranty... i was always under the impression that the TSB called for the fuel hose to be replaced, IIRC.
Old Mar 2, 2009 | 08:05 PM
350Zed's Avatar
I have the same problem... sometimes I can fill without problem, sometimes I can't even get more than a few liters in before the pump cuts off, as if the tank's near-full.
Old Mar 2, 2009 | 08:12 PM
jetdoc's Avatar
Brother, I called the dealership and they said pound sand, so I called Corporate headquarters and they told me the same thing, if its out of warranty they do not have to do the TSB....as some have said, they CAN do it, however mine wouldn't.
Old Mar 2, 2009 | 10:46 PM
baileyt35's Avatar
Would be nice if they would have a TSB for the 07-08's!
Old Mar 3, 2009 | 01:00 PM
scotts04MT6's Avatar
Same issue with our 04' 350Z and my 04' coupe. I'm sad to read it's still a problem even with 06s.
Old Mar 3, 2009 | 04:47 PM
_KyL_'s Avatar
And here i thought I was the only one with that problem. I'm always being asked by the gas station attendant if everythings okay or asking whether the pump I'm using is acting up because I'm feathering the pump handle the second I start filling. Its actually pretty embarrassing.
Old Mar 4, 2009 | 12:18 AM
Boostwhore's Avatar
lol mine does it all the damn time bugs the **** out of me... is this probably only under the bumper to bumper warranty?
Old Mar 4, 2009 | 12:25 AM
jetdoc's Avatar
Boost, if you have your warranty then yes, however as we have been saying some of the more professional dealerships have been doing the TSB's even if you're out of warranty.
Old Mar 5, 2009 | 01:49 PM
nghiars's Avatar
I didnt know that. I just had that assumption since Honda did a recall for me when i was out of warranty.
Old Mar 19, 2009 | 10:44 PM
dwrecckk's Avatar
I had this fixed for me under TSB ITB08-041A
Parts: Ring-O Fuel Gag?
and BRKT - Evap Cut
No idea what that is.
Old Mar 19, 2009 | 10:55 PM
infinus's Avatar
I thought recalls were mandatory fixes regardless of warranty because they are a safety issue, TSB's are only under warranty and not necessarily safety related.
k67p67
Engine - Power Adders
Aug 29, 2015 08:19 PM
suprhulk
May 24, 2003 06:18 PM
DallyCurtis
May 8, 2003 12:48 PM
Need4Speed
Dec 1, 2002 07:41 AM
