TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Car hesitation at take off - 2007 G35 Sedan
Old Aug 28, 2020 | 05:57 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Sounds like a vacuum leak. Clean the MAFs, pull and inspect your spark plugs, look for any leaks while doing those two things.
Old Sep 8, 2020 | 12:06 AM
nick odonnell's Avatar
07g35x
5at vq35hr issues
I cleaned maf,changed spark plugs with oem.passenger side by the firewall had oil in the spark plug well,changed them all out with new oem ones.bought another ecu had Nissan reprogram n do all procedure,changed upper and lower intake gaskets ,changed exhuast gaskets all with oem,changed all four cam sensors and crank sensor,checked for leaks with water n soap,n carb cleaner...car temp goes above normal.then idle starts to raise up to 2k then boom!! Idle hunt ....unless I turn on AC and all the loads then idle goes down to 1100.when car is cold it runs like an animal..I'm so lost !!!!!!!.when I turn on AC I can here if one of the pulleys are going bad IDK ..this is a good one..
Old Sep 8, 2020 | 09:26 PM
Pj9ball's Avatar
Infiniti g35 sedan
I’m having the same problem is it the fuel pump cause at the stop sign my car jerk to go like it’s hesitant
Old Sep 8, 2020 | 09:41 PM
07g35x
5at vq35hr issues
Not sure.i know it's getting fuel because I just changed upper and lower intake gaskets and gas just poured all over me on a count of I didn't release gas pressure..I hope it's not my head gasket.hesitation only when warmed up.n my scanner say it's going over normal temp.got to figure why it's going over temp
logicalswan
Sep 13, 2016 07:56 AM
AnthonyJohn
Jun 18, 2016 03:52 PM
Ferrarimanic360
Jun 6, 2012 08:54 AM
treacherous
Oct 5, 2011 07:17 PM
k_lundquist
V36 General Tech Questions
Aug 29, 2008 09:39 PM
