TSB- Technical Bulletins Technical Service Bulletins- Coupe and Sedan from Infiniti. Updates Approved by Administrators and Moderators.
Engine Coolant Effects Manual Transmission?
Old Feb 4, 2019 | 10:29 PM
Surrey's Avatar
Exclamation Engine Coolant Effects Manual Transmission?
Been lurking for years. I finally have a problem I can't figure out using my search skills :P (search the words coolant and transmission, well, you can imagine)
Driving home today, clutch was feeling weird and I was starting to smell clutch smoke. I stopped in neutral in an alley by my house. While sitting still the smoke was billowing from under the hood. Yikes! I depressed the clutch pedal and the engine RPM dropped and I could hear and feel friction like the throw out bearing was ceased. Okay fine. Clutch was slipping while I was driving? Okay weird/fine. I put her in 1st and got a boost of speed, enough to coast home. I park it and popped the hood. Coolant blasted everywhere.
Note, the engine was not overheated as per the temp gauge, and I could sense no excess heat, actually, I have had a slow coolant leak near the filler cap as of the last few weeks and I guess it just got bigger just now.
Is it possible that a plume of coolant could make it into the Manual Transmission and screw with the clutch and/or throw out bearing?
Thank you in advance for any ideas!
Regards,
Jonathan.
Old Feb 5, 2019 | 02:28 PM
cswlightning's Avatar
There's no way coolant can get anywhere near the clutch assembly short of a bath in it. Two separate issues it sounds like.
Old Feb 5, 2019 | 03:21 PM
cleric670's Avatar
BANNED!!!
Coupe 6MT Premium RAS
Cracked block, I can't remember for sure but I think there was also a freeze plug in the back, one of those threaded plugs.
Old Feb 6, 2019 | 01:23 AM
Surrey's Avatar
Oh please don't say that lol.
But yes, thank you for the tip. I will investigate a cracked block.
gshadyz
DFW Classifieds
Jun 22, 2011 01:41 AM
Blackbird V35
Cooling
13
Jun 19, 2011 06:35 PM
Andrei
Dec 18, 2010 12:41 AM
EvolutionGSR
14
Aug 16, 2008 04:52 PM
MrPotatoeHead
Nov 17, 2006 01:16 PM
