UTEC vs UNICHIP
Old Jan 8, 2007 | 07:20 PM
exopina's Avatar
UTEC vs UNICHIP
ok guys newbie question....what is the difference betweeen the UTECH and UNICHIP? Which one is better? I was leaning toward UNICHIP. Also do either of these modify shift points, and not just redline and air/fuel ratios..etc...
Old Jan 8, 2007 | 07:41 PM
QuadCam's Avatar
are you a DIYer? if so, go UTEC all the way. The UTEC is user tunable....that is enough for me!
Old Jan 8, 2007 | 08:08 PM
ballisticus's Avatar
Neither will affect shift points. To make any meaningful difference there, you are talking TC and valvebody upgrades. Not really worth doing unless adding FI or building a potent NA motor.
Old Jan 8, 2007 | 09:04 PM
booger's Avatar
The Utec is going to be a better EMU . As far as shift points . The G35 has seperate TCM that controls the tranny shift points
Old Jan 9, 2007 | 09:52 AM
exopina's Avatar
Ok so UTEC is the preferred way to go. . I plan on making the following upgrades(listed Below). I see Stillen offers the tranny software upgrade. So you think it would benefit getting the stillen upgrade for the tranny. Will that drastically help performace?
Still Gen 2 Catback and headers
Motordyne MREV2 and 5/16 spacer
Stillen Z-Tube and K&N Drop in Air Filter
UTEC EMU
P.S I can't wait to see the gains I get from all these mods
Old Jan 24, 2007 | 06:20 PM
Greatwars's Avatar
Unless you go FI, I don't see any reason you need UTEC .... basically with your modifications alone, you don't really need ECU unless you really want to extract max 10 whp more ....
Old Jan 25, 2007 | 04:40 AM
98intrigue's Avatar
I gained 15whp across the entire rpm curve when I added the Utec...the power gained is mostly in the tuner's hands, and I had a great tuner. If you have the money for it, go for the Utec. Plus it will be there in the end when you go FI
Old Jan 26, 2007 | 02:08 PM
Skaterbasist's Avatar
Retired SuperMod
With many bolt-on's, a stock G would be running lean without a tune.
Old Jan 26, 2007 | 04:15 PM
badlittleboy007's Avatar
how much do they ususally charge for tuning your car???
Old Jan 28, 2007 | 10:56 AM
QuadCam's Avatar
it varies widely. I have seen pirces from a couple hundred up to $750.
Old Jan 30, 2007 | 08:53 AM
Julian's Avatar
That is incorrect..We have seen upwards of 23 whp throughout the powerband on some cars..The average is about 10-15 whp, but its not just peak usually..
Old Jan 30, 2007 | 09:15 AM
Audible Mayhem's Avatar
+1 utec is the perfect step towards going FI, i have tuned many cars with it and you can get all the boltons you have done to finally work correctly.
then, when you go FI, its one less thing you need to buy at once..
Old Jan 30, 2007 | 09:17 AM
just so you know, that is not always true, i have seen cars come in with many bolt ons running really rich and really lean, and some are pretty damn close to ideal AFRs.
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
EliteG
Engine - Electrical
Aug 5, 2015 07:50 PM
Mike@Altered
Dec 9, 2005 12:52 PM
dave@altered
Dec 6, 2005 04:17 PM
Dizzy
16
Nov 19, 2004 02:03 PM
