UTEC MAPS for my mods? Any advice?
Old Jul 19, 2007 | 02:05 AM
805g's Avatar
Just bought a utec, need to start a hunt for maps that match my mods.
1. UR pulley set
2. MD 5/16 spacer
3. injen CAI
I will need to coaching to start understanding this utec tuning.
I have a laptop that i will be able to use with the utec to tune. Also have good understanding of computers.
Yet tuning is something entirely foreign to me. ANY help would be great guys. Thanks.
Old Jul 19, 2007 | 10:25 AM
Marshall2K's Avatar
Here you go, this is a thread about sharing UTEC Maps:
http://www.350z-tech.com/forums/The-...17062.html:11:
Old Jul 19, 2007 | 10:50 AM
trey.hutcheson's Avatar
First, did you buy the tuner wideband? If not, then you need some method of logging your a/f's in realtime.
Second, spend some time in the Tuning section at my350z. A lot of information and resources there. Here's the link: http://www.my350z.com/forum/forumdisplay.php?f=448
Old Jul 19, 2007 | 11:31 AM
805g's Avatar
A/F? Don't know what that is....
Old Jul 19, 2007 | 11:38 AM
Air/Fuel ratios. The stock ecu will tend to run lean in closed loop, for maximum fuel efficiency and to reduce emissions. In open loop, it will run richer, especially as the engine approaches redline. It's typically in the neighborhood of 12.0:1.
These engines make most power right around 13.0:1 or 13.1:1. In order to achieve that target, you must know by how much you wish to offset the MAF signal to the stock ecu. In order to know that, you must have some way of determining your current a/f's at the various load points. That means you either use a wideband like the Turbo XS Tuner Wideband, you dyno-tune it, or you use a tool like Cipher to datalog the factory widebands if your car is an 04.5 or newer.
Old Jul 19, 2007 | 05:28 PM
FI'ed G's Avatar
Then you're not even ready to do any kind of tuning. Go to a shop and let them do it then read some book about tuning and how they work in general before you jump in.
Old Jul 19, 2007 | 05:36 PM
805g's Avatar
well thank you for the help.
Old Jul 19, 2007 | 10:19 PM
FI'ed G's Avatar
If you're interested in doing some minor tuning then you can buy this book.
How to Tune and Modify Engine Management Systems by Jeff Hartman
Amazon Amazon
also a good reference for FI is Maximum Boost by Corky Bell.
Amazon Amazon
Old Jul 19, 2007 | 11:46 PM
GreenGoblin's Avatar
The goblin resurrection
ya i wouldnt mess with it if you dont know whatyou are doing for best results you shoulod take it to someone that knows all the tricks
B03Sedan
Sep 22, 2015 10:37 PM
bigmike
Sep 17, 2015 01:58 PM
Paragham
Sep 15, 2015 12:04 AM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
