ECU reset impact?
Old Aug 21, 2007 | 02:20 PM
shdowflare's Avatar
ECU reset impact?
Hey all,
I wanted to do the hard pedal ECU reset to see if it resolves an electrical problem I'm having. However, I wanted to know if this would erase the ECU reflash I had done at AAM last year?
I called AAM and they said it shouldn't but their answer didn't leave me feeling 100% confident. Anyone know if the manual reset will revert any of the hard-coded ECU ROM settings done during my flash?
Thanks,
B
Old Aug 21, 2007 | 07:58 PM
fortified's Avatar
It should not be affected. You can just remove the battery for several hours or overnight if you feel better. That should work too.
Nobody would get their ECU flashed if it would erase the program every time the battery was disconnected for a while.
AAM, etc. flash an eprom that needs to be re-flashed to change it.
Old Aug 22, 2007 | 02:04 AM
shdowflare's Avatar
Thanks. I'll move forward with the reset then.
Old Aug 23, 2007 | 03:24 PM
ttrank's Avatar
Grocery getter
^+1
ttrank's Avatar
Grocery getter
^+1
Just do the reset or pull the negative battery terminal overnight.
Old Aug 23, 2007 | 03:31 PM
shdowflare's Avatar
What ECU settings are reset when I disconnect the negative terminal overnight? In other words, what will my car have to "re-learn"?
Thanks,
B
06g35
Feb 14, 2022 05:59 AM
esotericrider
V36 General Tech Questions
Mar 4, 2019 07:53 PM
MThawkins86
Oct 24, 2015 02:07 AM
vamarris
Sep 26, 2015 12:56 PM
