best tuner
Old Mar 24, 2008 | 04:54 PM
adog35's Avatar
best tuner
hey i want to order a tuner for my 2004 g35 coupe. i dont want to send my ecu out i just want a plug and play one with differen maps. which one would u recomend? i was looking at unichip and a tuner made by uprev. let me know thanks.
Old Mar 25, 2008 | 04:01 AM
G37Rider92649's Avatar
+1 Utec
Old Mar 25, 2008 | 06:03 PM
_jb's Avatar
_jb
Photographer
I recommend getting Osiris from UpRev. You can flash your ECU using their program and a notebook computer. You don't have to remove your ECU or install anything.
It loads five (5) maps of your choice into unused memory areas on the ECU and you switch maps with the Cruise Control buttons. It works well.
http://uprev.com/products/osiris_NI.html
There's the link...
Old Mar 26, 2008 | 11:41 PM
OCG35's Avatar
+1 for Osiris
Old Apr 22, 2008 | 04:03 AM
nutt's Avatar
with osiris dont you loose your stock settings? i mean I herd that alot of people like to keep the stock settings for later use and say buy a utec were it uses its own pogram without reflashing the oem ecu?? im trying to learn this any1 can clear this up for me???
nutt's Avatar
Old Apr 22, 2008 | 07:07 AM
App6MT's Avatar
Littering and...
Haltech
Old Apr 22, 2008 | 07:13 AM
EvolutionGSR's Avatar
You could lose your stock settings if you chose to do so I guess. I have my osiris done where whenever I start my car, it starts on the stock setting. I have to use the cruise control buttons to change to my tuned map.
Old Apr 22, 2008 | 10:49 AM
OMG35S's Avatar
Wait for the Cobb Access Port...
Old Apr 22, 2008 | 11:38 AM
_jb's Avatar
_jb
Photographer
Osiris provides five (5) maps. Most people keep the stock map as one of the five maps. That way you can run the stock map whenever you want. You do lose the 100% pure settings that came on your ECU. The difference is that you now have Osiris and the extra maps in ROM (EEPROM actually). I believe UpRev can return an ECU to its 100% pure state, but you have to mail it off to them.
I don't know many people that have a UTEC and Osiris on normally aspirated cars. The UTEC has some issues controlling NA cars. There are reasons to use a standalone EMS with Osiris, but that gets expensive and doesn't benefit all cars.
You miss out on some performance if you always load the stock map every time you start your car.
Osiris (and any flash really) sets the "Targets" in the ECU. The advantage is that the ECU learns towards the settings you want, rather than the settings Infiniti programmed in. The Infiniti OEM settings are designed to keep the engine parameters set to control emissions. An Osiris tune sets the ECU parameters to give good performance.
You should select the map designed to give you the best performance and leave it there. That way your ECU will learn towards your performance settings and your car will run better.
Old Apr 22, 2008 | 11:47 AM
FastDontLie's Avatar
...we dont need roads...
go with the Utec...
Old Apr 22, 2008 | 11:55 AM
NorthSideRacing's Avatar
U-Tec or HKS V-Pro
Old Apr 22, 2008 | 12:15 PM
OCG35's Avatar
I had always believed this to be true as well... however, Shawn Church told be there really isn’t any "learn towards" - once you set the specific map those parameters are happening right then... I was concerned about running race gas at the track with the race gas map and not driving the car prior to runs in that map... the way I understood Shawn’s explanation is that it will immediately use the race map settings.
Old Apr 22, 2008 | 02:19 PM
jonnylaw's Avatar
Actually, the ECU takes longer to learn different octane settings than it does target A/F, cam timing changes, etc.
But I really wouldn't know since I only have 1 osiris map
