Utec Map switch help
Old Nov 23, 2008 | 06:29 PM
SilverG123's Avatar
Were do you guys mount the switch. i want to put it by the vdc button and get rid of the trunk button but is their enough wire to reach the ecu? Thanks for your help.
Old Nov 23, 2008 | 10:22 PM
str8dum1's Avatar
no, but all you need is some wire and solder.
Old Nov 23, 2008 | 10:35 PM
express705's Avatar
im going to put mine in the center console.
Old Nov 24, 2008 | 11:36 AM
express705's Avatar
bump for some more options
Old Nov 25, 2008 | 02:54 AM
2slo2bfurious's Avatar
put it in the glove box, that way you can lock the glovebox... and nobody will mess with it.
Old Nov 25, 2008 | 10:46 AM
GreenGoblin's Avatar
The goblin resurrection
^ That is what I said to do also
Old Nov 25, 2008 | 11:59 AM
str8dum1's Avatar
ya, i have mine near my vdc and find it easy to knock/change maps inadvertently. glove box is easy bc no soldering.
Old Dec 4, 2008 | 03:36 PM
ttrank's Avatar
Grocery getter
Mine is up in the upper glove box by my EDFC, Boost controller and UTEC Tuner display. I also keep the serial cable for the UTEC up there so it is easy to access.
Dallsinghjr1
Sep 17, 2023 11:25 AM
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
vamarris
Sep 26, 2015 12:56 PM
master111
Sep 25, 2015 08:32 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
