Getting SEL after Vortech/Osiris Tune
Old Dec 31, 2008 | 11:42 AM
LowUFO's Avatar
Question Getting SEL after Vortech/Osiris Tune
OK, here are the basics....
2005 Infiniti G35 6MT Sedan (Rev-up)
Vortech V3 Tuner Kit
600CC Deatchwerks Injectors
Walbro Fuel Pump
AAM Basic Fuel Return System (Modified to fit the Sedan)
Osiris Pro-Tune performed by EIP Racing in San Jose, CA
About once a week, I get a SEL code P0300 Random Misfire code.
I am able to clear the code with the Cypher, but about a week later, the SEL comes back, same code. It doesn't come on after a hard run, but when I'm sitting in traffic, or at a light.
I did drive the car about 10 miles to EIP before the tune, with the 600CC injectors & Walbro. Could I have fouled out the spark plugs? They are the original plugs. Should I try replacing them with new Denso Iridiums?
Does anyone have any other ideas as to what could be causing the SEL?
Thanks,
Ian
Old Jan 14, 2009 | 03:28 PM
4drmadness's Avatar
im thinking spark plugs could be your problem as well. i am gona get a tune as well, and people have told me that it is a very good idea if you change your spark plugs before the tune
Old Jan 14, 2009 | 03:29 PM
Dustin@StrafeAutomotive's Avatar
Really Needs a Life
common problems on the Vq my friend with the cel..
Old Jan 14, 2009 | 03:32 PM
GreenGoblin's Avatar
The goblin resurrection
Its a very common occurance with boost
Old Jan 14, 2009 | 03:34 PM
Really Needs a Life
heard ya got the white smoke mod.. lol fun mod huh?
Old Jan 14, 2009 | 03:40 PM
lekker_droom's Avatar
Well FWIW, I had UpRev change out my plugs at the time of them tuning as well and no issues.
Old Jan 14, 2009 | 03:47 PM
Really Needs a Life
mhmm little different when your not boosted..
but our engines under boost will always throw codes..
Old Jan 14, 2009 | 03:49 PM
^^true, just putting it out there.
Old Jan 14, 2009 | 04:03 PM
Ya its burning the blow by oil, and I haven installed a catch can yet. It only does it if I rev it with no load. If I am on it I have the black smoke mod.
Old Jan 15, 2009 | 12:28 PM
LowUFO's Avatar
Thanks for all of the input. It ended up being a fuel problem. The AAM fuel return system I have is for the coupe, and had to modify it to fit the Sedan. (Since they don't make one) Basically I am only using 1/2 of the gas tank due to the swirl jet not being reinstalled properly. When I hit 1/2 tank, I'm out of gas. The SEL was basically from the sputtering from not getting enough fuel. For now I have to fill the tank every 100 miles or so, until I can get the fuel tank issues worked out. No SEL's since I figured out the issue.
Thanks again,
Ian
g.spot
May 9, 2016 10:54 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
AJC128
Nov 1, 2015 11:55 AM
Usman Ali
Oct 4, 2015 08:23 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
