Osiris Tuned: Dyno Sheets FTW!
Old Mar 28, 2014 | 10:48 AM
  #271
OceanDriveDrizz's Avatar
Originally Posted by LOLmustangLOL
Jeez these are almost STOCK numbers bro
Originally Posted by herrschaft
Compared to another G35 in CT on the same day and same dyno??? The numbers may seem low but you can't compare dyno numbers if there's no controlled variables.
Yeah exactly what Herrschaft said. One of my boys ended up going on the same dyno with his stock rev-up and put down 212hp so my gains are definitely legit. When I first got it tuned I made the mistake of comparing it to different locations and dynos.
Old Mar 28, 2014 | 11:21 AM
  #272
Shawno72's Avatar
Sub'd
Old Mar 28, 2014 | 01:46 PM
  #273
LoSt180's Avatar
Originally Posted by serega13
06 6MT 291whp on what turned out to be low octane gas, probably be a little closer to 300 with good gas.
Mods:
K&N filter
Z tube intake
Motordyne MREV2 lower plenum
Motordyne 5/16 plenum spacer
DC Sports headers
Fast Intentions HFC
HKS replica exhaust
Magnaflow x Pipe mod
AMS Aluminum pulleys with idler delete
Z1 Aluminum driveshaft
Man I wish Frank still had that dyno when I went to him so I could compare ours better.
Tuned at Hill's Garage, they were using a brand new DynoCom 4wd capable dyno and they were still working out the kinks. So this shows good gains, just kind of heart breaking numbers.
Car: 06 6MT
Mods:
Stillen CAI
OEM Z-Tube
Custom port non-revup lower plenum
Motordyne 5/16 Plenum Spacer
AAM Competition HFC
Fast Intentions Cat Back
Idler Pulley Delete
My car also had a baseline map tune from seymore4 and the first few pulls after the baseline actually LOST power. But was able to see some nice under the curve torque gains and the car wants to launch forward now. They also smoothed out the power loss above 6200 RPM that comes with using the non-revup lower plenum.
Old Mar 28, 2014 | 09:46 PM
  #274
izzueeek's Avatar
Just had my tune done today. It was on Mustang dyno, he told me that these dyno will read super low.
Mods:
Nismo CAI
MD 5/16 Plenum Spacer
MD MREV 2
MD Art Pipes
Nismo S-tune catback
Old Mar 28, 2014 | 11:11 PM
  #275
Urbanengineer's Avatar
Originally Posted by izzueeek
Just had my tune done today. It was on Mustang dyno, he told me that these dyno will read super low. Mods: Nismo CAI MD 5/16 Plenum Spacer MD MREV 2 MD Art Pipes Nismo S-tune catback
All that and only 240? Are you auto?
Old Mar 28, 2014 | 11:16 PM
  #276
izzueeek's Avatar
No 05 6MT Rev Up
Old Mar 28, 2014 | 11:30 PM
  #277
Well I know I'm in the sub 220 category then if you have all these modifications and are at 240!
Old Mar 28, 2014 | 11:49 PM
  #278
Lartytiejdke3's Avatar
Really only 240?
Chittt these cars are slow
Old Mar 28, 2014 | 11:51 PM
  #279
seymore4's Avatar
m56
Really only 240?
its just a number...
Old Mar 28, 2014 | 11:53 PM
  #280
izzueeek's Avatar
Would you say 14whp 15tq is reasonable gain?
Old Mar 28, 2014 | 11:54 PM
  #281
A low number at that, wouldn't you say?
Old Mar 28, 2014 | 11:56 PM
  #282
seymore4's Avatar
m56
I would
gains matter, #'s do not. I've seen almost identical cars put down 220 on one dyno and 290 on another.
Old Mar 28, 2014 | 11:58 PM
  #283
izzueeek's Avatar
I would
Is there any reason why its not higher?
I am on some 20 inch wheels lol
Old Mar 29, 2014 | 12:04 AM
  #284
seymore4's Avatar
m56
You just answered your own question.
Old Mar 29, 2014 | 10:10 AM
  #285
VQ35Monstar's Avatar
Originally Posted by DrewDrew
AFR was 14.5-15.1 throughout the entire range on the baseline - ultra lean due to the MREV2 - 15.1 AFR peaked at 4100 rpm.
Gains: +18hp/+30tq at 5300 rpm.
Final tune: 281hp/258tq.
Shawn also lowered the temperature at which the radiator fans turn on to 98*C (208*F) over the stock 103*C (218*F), increased the torque management on the transmission to improve crisper and faster ***** complementing the TransGo, along with AFR, Cam, and ignition timing.
Related list of mods:
- 350z Air Box
- Z-tube w/K&N Drop-in Filter
- xSxExCx Intake Mod
- xSxExCx Grounding Kit
- Motordyne 5/16th Copper Iso-thermal Spacer
- Motordyne Shockwave V2 TDX Exhaust
- Motordyne ART v3 Pipes
- Motordyne MREV2
- Osiris Tune by Church Automotive
- 3.692 VLSD Final Drive
- TransGo Valve Body
- Mishimoto Oil Cooler
- B&M 21 row Transmission Fluid Cooler
- Powertrain Industries 1pc. Lightweight Aluminum Driveshaft
The car just pulls in any gear at any rpm, and when it's time to shift, it shifts faster than I can blink now. Very happy with the tune at 125k miles. Time for a compression and leak down test to see if it's safe to move on to Vortech. Always open to questions. I'll be back with an edited video of the tuning.
You can see a bunch of runs on my channel.
2005 Infinti G35 Coupe Tune @ Church Automotive Run 4 - YouTube
What motor?
