View Poll Results: Retune?
Yes
50.00%
No
50.00%
Voters: 2. You may not vote on this poll
Detuning a 2005 g35 5AT
Old Sep 21, 2011 | 03:07 PM
saltyload's Avatar
So here is the mod list: Z tube, K&N filter, 5/16 inch MD Plenum spacer, MD ART pipes, fast intentions catback exhaust
I'm planning on replacing the exhaust with the stock one. However, this car was tuned with Osiris, would I need to retune it again? If I don't will this cause any kind of damage to the car or will it affect it in any way?
Old Sep 21, 2011 | 03:27 PM
Canadian's Avatar
Canada, eh?
I would flash it back to normal so you can get your license back.
Old Sep 21, 2011 | 04:50 PM
saltyload's Avatar
The license/rights to Osiris? I spoke with the tuner and he told me I don't ever have to buy the rights, just pay for the tune.
Old Sep 22, 2011 | 04:01 AM
seymore4's Avatar
m56
That is correct, the licensing structure of Osiris works much Microsoft Windows or any other software, you pay for the license and once you've paid for it you own that copy of the software, which in this case is mated to your cars ECU. You can get reflashed/ retuned as many times as you want once the software is installed, consider it akin to creating a new word document in Microsoft office once.
As for getting retuned, it would be optimal to get it adjusted (shouldn't take more than an hour of dyno time for a protuner to adjust, so $160-200) but its not necessary for just a change in the exhaust. You'd have a much worse running car if you flashed it back to stock, the car wouldn't be able to compensate for all the extra airflow and will run lean. If you're reinstalling the OEM cats with the exhaust I would definitely get back on the dyno tho, that will make a pretty big difference.
Old Sep 24, 2011 | 10:34 PM
saltyload's Avatar
Thanks man, I'm probably gonna go retune so it runs well with the oem exhaust (was quoted $150 for one hour)
Old Oct 5, 2011 | 06:58 PM
saltyload's Avatar
I plan on removing the exhaust and Y pipe and replacing them with stock. Will I need to retune to stock/stage 1?
Old Oct 13, 2011 | 10:29 PM
saltyload's Avatar
ok so I'm definitely changing the exhaust back to stock, but a friend just told me I need to use a stock Y pipe as well. The car is going from catless to a cat. It's also tuned for the mods in post 1. Will this require a retune?
Old Oct 13, 2011 | 11:27 PM
MikieDG35's Avatar
How come you changing it to the OEM ?
Old Oct 14, 2011 | 05:41 PM
saltyload's Avatar
The exhaust drones like crazy. I can't hear my radio or speak inside the car if I'm pressing the gas pedal even if I'm only at 2k rpm. Also, I want the jet engine exhaust note that came from factory.
laksjd84
Feb 28, 2026 01:58 PM
Blakelyg35
Aug 15, 2015 12:12 PM
lemmy999
Jul 25, 2015 12:13 PM
AustinErkl
Drivetrain
Jul 18, 2015 05:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
