Reflash from Auto to Manual trans ECU?
Swap wiring
I’ve just completed swapping from 5AT to 6MT in an 04 Coupe. The only thing swapped was the Transmission so the ECU and engine are all stock 5AT. PNP, Cruise Control, Reverse, and Neutral switches are wired up. The car starts and runs. I’m just looking to get rid of that pesky “Check AT” light that flashes. I do have the UPREV tuner license, but I’m having a hard time finding the feature to swap from Auto to Manual. Is this something that is only done with the “Pro Tuner” features or am I just blind?
Pretty sure you scrolled past the thread you meant to ask the question in and into another thread.
I can do it for you as part of an Uprev reflash. I will PM you
Swapped g35 from auto to manual
hi bro how are you i swapped my G35 from automatic transmission to manual but i kept the automatic ECU and the electric cable and its giving me codes of camshaft sensor and vanos and airmass but not all time those codes are going and comming btw the car is tuned uprev and arc what can i do to finish this problem maybe its a remap or what ?please help guys
hey seymore, I would like to talk to you about the Uprev tune. For some reason I can’t pm anyone on here though. Do you have another form of contact we can use?
Vash
12
Jan 9, 2010 09:29 PM
