New to uprev, i have questions
Old Jun 26, 2014 | 04:41 PM
Phteven's Avatar
I got my uprev cable and was expecting to get a base tune with it after having to fill out all the info about what mods I have and what each tune is supposed to be. So to my surprise I just get the cable and a sweet sticker. My bad for my lack of reading comprehension with their website.
So my questions are:
When I do the data logging and email it to uprev do I have to do 5 separate logs (one for each of the tunes) even if a couple of the tunes are for valet and economy?
If I want a 91 octane and a 93 octane tune do I need to switch fuels for the logs?
Sorry but I'm a newb to the tuning arena. My only other experience has been with bully dog tunes with trucks.
If it matters I drive a 2007 G35 coupe 5at. With basic breather mods: MD plenum spacer, Stillen intake/z-tube, MD ART pipes.
Old Jun 27, 2014 | 10:15 AM
Phteven's Avatar
Bump
Old Jun 27, 2014 | 10:30 AM
yosip1115's Avatar
Originally Posted by Phteven
Bump
You really shouldn't tune it yourself because bullydogs do not give you nearly as much control as uprev does. You can blow your motor really easily with this, not with a bullydog.
That being said, you do not need to switch fuels. Just back off the timing for your 91 octane map.
Old Jun 27, 2014 | 10:40 AM
Phteven's Avatar
I'm not tuning it myself, I am sending logs in to uprev for them to create the tunes.
Old Jun 27, 2014 | 12:15 PM
yosip1115's Avatar
Sorry about that, I missed some important details. They will modify your map accordingly no need to run 91 and 93. How are those ART pipes??!
Old Jun 27, 2014 | 12:35 PM
Phteven's Avatar
Thanks. I like the ART pipes a lot. They were easy to install except for the top nut on the drivers side due to the steering shaft being in the way.
Old Jun 27, 2014 | 01:07 PM
LoSt180's Avatar
Uprev should email the base tune file to you (it includes all of your requested maps). It won't come in the package. If you haven't gotten the base tune file, they might be waiting on you to reply with the ECU part number. You get that by plugging the cable into your car and opening up Cipher. For example, my ECU is CM41B, but if you look at the support matrix there's like 8 different ECU numbers for every year G.
For the Etune, you should just have to do one set of logging, I forget what they ask for, should be listed on the site though. Might need 2 sets if you want to really dial in the 91 & 93 octane tunes.
Email Uprev directly with your questions, or send a PM to seymore4 he knows his stuff and is pretty helpful.
Old Jun 27, 2014 | 03:21 PM
JKL1031's Avatar
Should I get a tune with just HFC, k&n, and a y pipe? I don't plan to go full exhaust.
Old Jun 27, 2014 | 05:45 PM
seymore4's Avatar
m56
Yes. HFC make more of a difference than the cat-back
Old Jul 8, 2014 | 03:39 PM
LaserRedG35VS's Avatar
Hey fellas, got a question on my tune. I'm about to install valve cover gaskets and was wondering if afterwards, I would have to do all the recalibration procedures after the install??? These procedures can be found here : https://www.motordyneengineering.com/manual.pdf .
I'm afraid I will lose the tune or something.
migurus
Sep 5, 2015 09:39 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
UT G35
Sep 3, 2015 03:58 PM
erich2780
Sep 3, 2015 03:23 PM
pdexta
Tuner & Dyno
Sep 2, 2015 01:03 PM
