Options for ipod nano hook-up
Old Dec 26, 2008 | 05:31 PM
Eug96's Avatar
Hey everyone, i was just wondering what are the best options I have with hooking up my ipod nano to my 07 g. There is no direct ipod conection so my 1 option would be threw the cigarette lighter or the outlet in the arm rest. Also, there are the red, yellow, and white outlets, could i hook it up threw there with this cable....
http://http://www.provantage.com/cab...9~7CBTY00J.htm
If so would i have to Bypass the parking break.
(not trying to post about bypassing the break just wondering if thats what i would have to do)
Old Dec 26, 2008 | 07:01 PM
bfranks's Avatar
That cable will work, and you won't have to bypass the parking break to use it. The only thing that is disabled while the car is in motion is the video input.
There is however a direct wire solution. It's a bit costly compared to the cable you are looking at, and not as integrated as the 08 interface, but still an option. I'll try to find a link and post it in a sec.
Edit: Here are the links
Part
DIY on an 07 install with pics.
Old Dec 26, 2008 | 08:29 PM
mishmosh's Avatar
So still no ipod integration for Nav owners? I would definitely give up satellite radio for it but looks like the EverythingG35 does not work with Nav.
Old Dec 26, 2008 | 09:16 PM
bfranks's Avatar
It actually does work with Nav. Do a search on it and you will find lots of people using it. What the site is referring to is that you will lose the XM Nav traffic part while it is connected, since the interface overrides the sat signal. However this is also not true. Confused yet? The Nav traffic info comes in on a separate channel from the radio signal, so it does not get overridden. When I swapped out my Sirius tuner I used the exact same harness (although in nav equipped 08 models it's connected to the CD changer in the trunk) to connect to the Sirius tuner. I was able to receive Sirius and still have the XM Nav traffic working.
Old Dec 27, 2008 | 11:40 AM
Eug96's Avatar
bfranks, thanks for the info, i think im gonna go with the armrest outputs, the direct solution looks a little to complicated for me haha
seagrasser
May 3, 2022 09:43 AM
prinny
Nov 22, 2015 11:07 PM
ncg35guy
Sep 24, 2015 04:53 PM
