gps idea for non-nav sedans
Old Jul 25, 2011 | 07:53 PM
johnw999's Avatar
TME-S370 $249.99
NVE-M300 $260.99
HCE-C115 $134.99
KCE-900E $54.95
video trigger $15
chrome trim $60
wire harness $50
I got everything new from various sellers on ebay. So far, I've spent about $725
Old Jul 27, 2011 | 01:27 PM
GXXXV X's Avatar
are you replacing your OEM screen or adding this screen where the radio buttons are?
also, is this setup going to be able to tell you your climate control settings and use the steering wheel controls as well?
Old Jul 27, 2011 | 04:05 PM
johnw999's Avatar
I am replacing the OEM screen with the alpine. I will run the RGBS factory signal to the alpine screen, and it should show radio, climate control, etc.
Today, I finished gluing the alpine camera to the chrome trim. It's now secure and weatherproof. Next step is to attatch the new chrome trim, mount the small camera control box in the trunk, run wire from the reverse lights to the control box, and run camera feed to the front of the car.
Old Jul 27, 2011 | 10:56 PM
surfjax87's Avatar
This is a great thread, can't wait to see how it turns out.
Old Jul 28, 2011 | 12:05 AM
GXXXV X's Avatar
+1 this should be diy'd lol this project is 100% win
Old Jul 29, 2011 | 12:30 PM
johnw999's Avatar
got the camera and trunk chrome installed. Looks like there is already a stock connection for camera power supply. It's a plug that branches off the right reverse light. I'll investigate more today. It's so hot in Texas! I can only do a little at a time.
Old Aug 3, 2011 | 02:41 PM
johnw999's Avatar
Disclaimer - I'm just showing what I'm doing to my car. If you use this thread to modify your car, you do it at your own risk.
ok - I'm almost finished with installing the rear camera. The camera control box from alpine doesn't have a mounting bracket. Alpine just provided velcro strips for it. So, I mounted it in the bottom passenger side of the trunk. Next to the spare tire kit. It's in a corner, and I used silicone glue instead of the velcro strips to secure it.
Old Aug 3, 2011 | 06:54 PM
rdeol's Avatar
Subscribed!
Old Aug 3, 2011 | 07:08 PM
johnw999's Avatar
a view of the installed camera. I tested the image on the stock screen which will be replaced later. So far, so good.
Old Aug 5, 2011 | 09:18 AM
RemmyZero's Avatar
nice! i like what i see man! keep is informed!
Old Aug 6, 2011 | 05:12 PM
pricojorge's Avatar
yikes ... thats really low quality
But nice project !
Old Aug 7, 2011 | 04:50 PM
johnw999's Avatar
Remember, you’re looking at a picture of a picture.
It’s now time to connect the alpine KCE-900E to the tvandnav2go harness. I have a pinout for the stock LCD and the alpine nav cable. I noticed that other RGB converters need a 5v power supply. The alpine pinout has a 5v power wire, and the stock RGB area YS signal is 5v. I’m betting these two need to be connected. Other connections will be red, green, blue, rgb sync, and ground. I’ll use the solder iron for the connections. Progress has been slow due to the Texas heat. It was 106 degrees yesterday!
Old Aug 11, 2011 | 11:09 AM
johnw999's Avatar
connections are crude, but properly soldered.
Old Aug 12, 2011 | 01:51 PM
dohturdima's Avatar
Q to OP - did you want to get the backup camera with no distance markings? I have a Sanyo backup camera (that has distance markings) which I did not install yet + the chrome trim, right now am using Boyo license plate backup camera with parktronic sensors but wanted distance markings.
EDIT: I see that you decided to stay with Alpine components. I don't know whether it's the pic you took but the resolution of the Alpine backup cam seems worse than my Boyo License plate one...
Old Aug 12, 2011 | 03:33 PM
  #30
johnw999's Avatar
I've already got the alpine camera and trim installed. Thanks, though. Your sanyo camera should sell quickly. I don't think they make it anymore.
Here is the pinout for the alpine KCE-900E.
I used this chart when connecting it to the stock harness. Now I'm going to try to install the gps box and monitor control box above the passenger kick panel. I'll know soon if there is enough room up there.
