help please! 07 g35s help w/ fuses
Old Aug 10, 2013 | 09:17 PM
Michael Iellamo's Avatar
Hey guys i could really use some help. I have a 2007 g35s. Under the arm rest where you can hook up your phone(mine has the red/white/yellow connection) and where a charger port is, will not work. Neither of them work when i try to use it to charge my phone it gives no power, and when i try to hook up my phone using the connection that will not work either. I have located the 2 fuse boxes and checked most of the fuses and they are not blown. Does anyone know exactly which fuse connects to this? Or any other suggestions at all? Thanks in advance.
Old Aug 11, 2013 | 01:51 AM
Mike45's Avatar
Maybe the fuse is missing? If you baught the car per owned the original owner might have taken out the blown fuse and never replaced it.
Old Aug 11, 2013 | 02:24 AM
i checked both fuse boxes one on driver side and the one near the battery all are there, im reading there is a 3rd fuse box? could it be there?
Old Aug 11, 2013 | 02:30 AM
Mike45's Avatar
From what I know there are 2 and the one inside the car under steering wheel is for the components in the car.
http://image.shutterstock.com/displa...ne-6700903.jpg
This is a link to a pic comparing a blown fuse to a good one, I can be hard to miss a blown one
Old Aug 13, 2013 | 12:52 AM
IEMaestro's Avatar
I have the same problem in my car. Any more info on this?
Old Aug 23, 2013 | 06:34 PM
G Wiz's Avatar
There is another fuse box behind the battery. (terrible location.
Not sure if the fuse is there.
specialist
Jun 25, 2025 02:08 AM
nettcar
Aug 25, 2024 11:59 PM
Kng0fHrts
Sep 15, 2015 05:40 PM
cltucker11
Sep 17, 2012 04:30 AM
bfspider
V36 Interior, Exterior & Lighting
Mar 9, 2008 05:20 PM
