does 5mm spacer require extended studs?
Old Mar 12, 2008 | 11:04 AM
ommmjido's Avatar
im trying to put some 5mm spacers on the front wheels(aftermarket), im wondering if anyone has done this without putting extended studs and if u have any problem so far, thx!
Old Mar 12, 2008 | 11:31 AM
terrycs's Avatar
It also depends on the wheel (how thick is the wheel under the nut) and nut. Technically speaking, you really want to know how much thread engagement there is and what the thread material is.
I've run 4mm on mine using rays nuts up to 100 ft-lbs torque.
Old Mar 12, 2008 | 01:26 PM
Wei's Avatar
Wei
i'm just thinking out loud, but i 'think' it should be fine, 5mm is really small, you can always get the spacers and see how much thread is left on the bolt, then buy aftermarket nut if need be, if that doesn't work either, buy extended studs...
Old Mar 12, 2008 | 02:22 PM
Cali G's Avatar
interesting... I may try to add these to my G37 wheels to get them a slight bit more flush.
Old Mar 12, 2008 | 02:37 PM
GreenGoblin's Avatar
The goblin resurrection
have a 5mm on the fronts on my car and it is perfect
Old Mar 12, 2008 | 04:27 PM
ttrank's Avatar
Grocery getter
It depends on how many turns you can still get with your lug nuts. It also depends on your power level. In general I think you can run a 5mm spacer and be ok.
My brakes have thicker hats and acted like a spacer on my car. I lost a few turns on the lugs so I changed out my studs to the 50mm nismo ones. They are not too expensive and good peace of mind.
Old Mar 12, 2008 | 05:11 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
You should get about 8 turns, any less & there's potential for trouble.
Old Mar 12, 2008 | 08:08 PM
codeflux's Avatar
yes, you need longer studs. get long nismo studs.
Old Mar 12, 2008 | 08:11 PM
JOKER's Avatar
CLUB MODERATOR
Get a longer studs with any kind of spacer.
You messing with wheels. You would not want them to fall off on you when you on the freeway do you?
studs are not that expensive. Dont hesitate, get them. Better be safe then sorry.
Old Mar 16, 2008 | 06:04 AM
ommmjido's Avatar
its not abt the money, its more abt the trouble. thx for the replies!
Old Mar 16, 2008 | 09:19 AM
Texasscout's Avatar
I put them on the front of my sedan. Factoy makeup is 9.5 turns. With the 5mm spacers, it was 6.5 turns. Not something I felt good about, so I put in the extended studs that came with the kit.
Old Apr 30, 2008 | 02:33 AM
hans127's Avatar
Did you end up getting the 5mm spacers?
the pics you posted, are they with the 5mm spacers. Did you end up putting them up in the front only or all around?
Thx!
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Ninjay16
Engine - Intake/Fuel
Jan 14, 2016 01:44 AM
the93owner
Oct 4, 2015 09:40 AM
w4kj4k
Oct 2, 2015 07:57 PM
