Anyone have any updates on camber kits?
Old Mar 18, 2008 | 02:16 PM
hans127's Avatar
Front camber kit?? Any word.
Eibach produces a rear camber kit for the 07 08 G35 sedan, but what I'm trying to figure out is do they make the Camber Adjusters & Rear Toe Arms for our car???
One "camber kit" was for 30.00 ...another one was going for 175.00.
http://www.drivewire.com/performance...gnmentkit.html
is it because one is the adjuster and the other is the toe arms?
What are majority of you using for the rear camber kits? Adjuster with no toe arms...or vice versa?
Old Mar 24, 2008 | 10:17 AM
kgreene's Avatar
bump
Old Mar 24, 2008 | 11:04 AM
TheIvoryG's Avatar
I don't think there is a front yet...we'll all waiting...
As for the price differences that you saw, I believe one is the kit that includes arms and toe bolts. The cheaper one is just toe bolts. You shouldn't need both, but its the arms that are the most important. Toe can get back into specs, camber can't.
Old Mar 31, 2008 | 07:55 PM
bertmauricio's Avatar
I installed my camber arms and brought it back to get it aligned. Well, camber is now in spec but now they can't get the toe in spec. I figured Toe would stay in spec but I was wrong. Arrrgh!
Have people been installing the Toe Bolts, along with the camber arms? This is the bolt holding the rear lower arm, correct? Just a matter of elongating the hole and using the new bolts?
Old Mar 31, 2008 | 08:07 PM
TheIvoryG's Avatar
You installed front camber arms?
Old Mar 31, 2008 | 09:58 PM
terrycs's Avatar
I have the toe bolts on mine.
Old Mar 31, 2008 | 10:55 PM
ckp's Avatar
ckp
are u running negative camber on your front tires?
Old Apr 1, 2008 | 12:02 AM
Sorry, I should have stated rear arms. Still no fronts for us.
Thanks Terry. I may just pay the shop to install and align, i'm tire of crawling under there.
Old Apr 1, 2008 | 01:26 AM
terrycs's Avatar
yes .. I am slightly out of spec.
Old Apr 1, 2008 | 02:40 AM
ckp's Avatar
ckp
^ whats your negative camber in the fronts?
Old Apr 1, 2008 | 10:05 AM
terrycs's Avatar
Details here:
https://g35driver.com/forums/showpos...&postcount=123
Old Apr 1, 2008 | 01:42 PM
ckp,
What numbers did you end with for your fronts after your drop?
With Eibachs, I'm -1.5 and -1.6 on the fronts.
zoop425
Mar 29, 2016 05:51 PM
G4ORCE
Aug 22, 2015 01:16 PM
NohoG35revup
Aug 22, 2015 12:13 PM
socalg35x
Aug 7, 2015 09:36 AM
nascarbuff17
Jul 16, 2015 10:23 AM
