Will spare tire fit over *rear* Akebono brakes?
Old Oct 14, 2009 | 10:54 AM
soundmike's Avatar
Oops, i forgot you guys have gone wide
Ever considered a fix-a-flat? If i'm not mistaken, the FaF is at least TPMS sensor safe... and much cheaper, too.
Old Oct 14, 2009 | 11:55 AM
terrycs's Avatar
I've heard that any puncture sealant makes patching the tire more difficult because the tech has to make sure all the residue is removed for the patch to adhere properly. Someone with experience should chime in here.
As for the mini-compressor - I used to have something similar. IMHO, they are better suited for "light" duty. Unless it is a pinhole leak I doubt it would have the volume it takes to overcome a leak from a nice size nail hole. Plus if the tire is completely down, that little thing will take forever to fill the tire to running pressure. So ... a good size leak will make you already late to wherever you are going. And when you get there, you might have to fill it all over again to get home. At this point, your day is shot so you may as well have called a tow truck using Infiniti Roadside Service.
Old Oct 14, 2009 | 03:34 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
^ I agree... I'd prefer not to have to go that route.
I was glad that I never had to use the OE unit in my BMW.
They claimed they would seal a normal puncture though. (not just a pin hole)
I'm also trying to find something aftermarket that will work,
since chances are slim to none that I'll find a G37S spare up here in the GWN.
Old Oct 14, 2009 | 05:18 PM
Shamzk2's Avatar
Car-parts.com has all sort of spare tires. and stock tires calipers and w.e else stock..
thats where i got my replacement brembo caliper for my G
Old Oct 14, 2009 | 05:19 PM
soundmike's Avatar
Forgive my ignorance, but doesn't the Conti Kit work on the same premise as the FaF?
Does anyone know if there's an easy way to retrofit a BMW M3 wheel onto ours? I've seen some threads of how M3 owners are using Cadillac spares (at $99) for spares. Caddy = BMW = Infiniti (?)
Old Oct 14, 2009 | 05:22 PM
Shamzk2's Avatar
Different Off set From BMW TO G...
FYI If you want a G37s Spare.. its around a hundred bucks too nd it looks better lol... The Website listed below Shows a bunch of Recycler's even some local. Where you can Defiantly find G37 spares
http://car-part.com/
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
shavedcrx
20 Inch
Aug 7, 2015 04:14 AM
Popes
Jul 29, 2015 05:07 PM
mushu
Jul 15, 2015 03:55 PM
